Tranny grinding noise when accelerating...
Old Nov 3, 2002 | 10:42 PM
Scrub's Avatar
bow leggin'
Question Tranny grinding noise when accelerating...
Recently when i accelerate it sounds like the gears are grinding together. It sounds bad, and i don't think it's normal. Anyone know what it could be. It seems to do it between 1K - 3500 or around there. It usually doesn't do it in first gear. I just changed my fluid to synthetic in hopes to help out, but it still does it. Im hoping that it's not something too bad. Also since I installed a B&M short shifter i can hear the transmision more, but i think i just forgot to put the pad in the right way. But the grinding noise makes me cringe.
Old Nov 3, 2002 | 11:36 PM
duboisr's Avatar
It could be a bad bearing, anyway just take it out and take it apart and see before it has a major failure that will cost more to fix ,plus a tow bill
Old Nov 4, 2002 | 06:14 AM
Scrub's Avatar
bow leggin'
oh is that all? I might have a buddy of mine take a look at it since i don't have a lift of my own.
Old Nov 4, 2002 | 04:00 PM
I had a similar problem...the grinding sound came on around 2-3K rpm's during acceleration for me. Although I also was experiencing lack of boost. It turned out to be that the intake hose had come loose. I may be mistaking, but is it alright to use synthetic oil for the RX7?
Old Nov 4, 2002 | 09:13 PM
Scrub's Avatar
bow leggin'
yeah, a lot of people use it. an intake hose made the boost problem or the tranny noise? This noise is really bothering me. Im thinking about just buying an ACT street/Strip clutch and a light weight fly wheel, and while the tranny is out find out if it is a bearing or something else.
Old Nov 5, 2002 | 12:26 AM
Mr rx-7 tt's Avatar
rotary sensei
Peter says DO NOT USE SYNTHETIC OIL..in the tranny. Call him and ask, he will tell you why.
Old Nov 5, 2002 | 09:59 AM
Scrub's Avatar
bow leggin'
hmmmm, well when i go to get a new clutch and flywheel i will change back, but a lot of people do change to synthetic. I also changed my motor oil to synthetic. I don't plan on changing back.
Old Nov 6, 2002 | 02:00 PM
The loose intake hose caused the lack of boost, the sound however may be different from what you're hearing. It did sound pretty bad...like something was grinding...definately noticable. Are you hearing the sound in all gears but first? Yeah...I believe it says right in the owner's manual not to use synthetic oil or any additives.
Old Nov 6, 2002 | 02:04 PM
Scrub's Avatar
bow leggin'
It does say that as well as with motor oil. But back in 94 synthetic oils were not as advanced as they are now. I think it is one of the bearings, which i am going to change when i replace the clutch and flywheel.
Old Nov 6, 2002 | 02:35 PM
LAracer's Avatar
Don't people usually put Neo or Redline in the transmission? Aren't they synthetic? Am I missing something?
Old Nov 6, 2002 | 02:58 PM
Scrub's Avatar
bow leggin'
yup you are exactly right.
Old Nov 9, 2002 | 09:04 AM
Tim Benton's Avatar
FD title holder since 94
When you say bearings, are you referring to the throw out or pilot bearing?
Tim
Old Nov 9, 2002 | 09:07 AM
Scrub's Avatar
bow leggin'
Both
Old Nov 9, 2002 | 09:38 AM
Tim Benton's Avatar
okay, here's a question then, and I hope someone can help me with it. Noise coming from the tranny, in neutral, clutch out, push clutch in, noise goes away. Is that the pilot bearing going bad? A T-O bearing going bad means the opposite I think.
Thanks,
Tim
Old Nov 9, 2002 | 08:01 PM
Kas_Rx's Avatar
dont use synthetic in your engine. Synthetic oil does not have the minerals for the rotary engine to burn. It leaves carbon deposits from the **** it cant burn. You did know rotary's burn oil from the engine..
Use Penrite HPR40 (if avail in USA). Its reccomended and used by all rotary workshops in Oz.
Old Nov 10, 2002 | 04:22 PM
Tim Benton's Avatar
Any ideas on my situation? T-o bearing? pilot bearing?
something else I'm not thinking of? Fluid level is fine.
Tim
Old Nov 11, 2002 | 07:52 AM
Scrub's Avatar
bow leggin'
Someone had said something about that before, my car does the same thing when you are in netural and you press the clutch in the noise goes away. I believe it is the pilot bearing. I could be mistaken. About the synthetic engine oil. Synthetic engine oil has been debated many times in the past. After reading many threads i decided to switch to synthetic. Unlike dino oil, synthetic has a very low ash rate and does not cause as much carbon buildup.
Jetlag
Sep 29, 2015 06:52 AM
