Sponsored by: CARiD
wtf!!!
Old Nov 2, 2002 | 04:14 AM
rotaryrules's Avatar
wtf!!!
Hello all I have an 88 gxl and last night after leaving my friends house I noticed the car stereo light was a bit dim. A few minutes after, all the lights went dim and once I hit the brakes a few times the lights were pretty much out. The car's idle was kind of rough and pressing on the accelerator the car responded with much hesitation. btw- my voltage gauge was reading very low volts.It's obvious it's an electrical issue, any suggestions on what to check first would be much appreciated.-----Ren
Old Nov 2, 2002 | 09:14 AM
eddierotary's Avatar
back with rotaries
did you check the battery cables? probably they are bad.
Old Nov 2, 2002 | 09:15 PM
duboisr's Avatar
your alternator may have gone out and the battery is drained. Do check your cables but that is more of a slow cranking problem. Just guessing because we are not there.
Old Nov 3, 2002 | 10:22 AM
IplayanRG's Avatar
Sounds like the alternator or alternator belt.
Old Nov 3, 2002 | 03:19 PM
diabolical1's Avatar
yep ... alternator issue
Old Nov 3, 2002 | 06:14 PM
I replaced the alternator today and sure enough my electrical problem was solved thanks for all you help guys- another rotary back on the road!!!
t-von
Sep 10, 2015 01:56 PM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
Wolf_
Aug 11, 2015 04:23 PM
Ryde _Or_Die
Oct 30, 2001 01:48 AM
