Changing the steering rack ratio?
Old Oct 29, 2002 | 02:29 PM
MtnRacer's Avatar
infini guru
Are there engineering companies that would adjust the ratios in a stock manual rack(FC in this case) for a price? Presumably a hefty price I'd imagine, but I thought I'd ask, since I wouldn't know where to look. Thanks guys!
Steve
Old Oct 31, 2002 | 02:36 PM
MtnRacer's Avatar
infini guru
Was this just a stupid question? Or does no one know?
Steve
Old Nov 6, 2002 | 02:34 PM
Zach McAfee's Avatar
FTD Wanna Be
bump, good Q.
Old Nov 17, 2002 | 04:43 PM
drago86's Avatar
i dont like the slowness of the manuel racks either, gtus is shorter, and so are the power assisteds when you de power assist them. shortest is power, gtu is close though
Old Nov 17, 2002 | 08:15 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
i saw an adapter in summitracing that coupled into the shaft going into the gear box that could reduce or increase the gear ratio by 30% or 50% depeding on which one you buy, and which direction you install it
Old Nov 20, 2002 | 01:43 AM
MtnRacer's Avatar
infini guru
Just for clarification, the GTUs steering rack was the same p/s rack that the TurboII got. Had a ratio of 15:1 I think. Mel, I checked out Summit's website, couldn't find anything even resembling what you were talking about... =P Think you could link me or tell me where I could find it? I'd appreciate it!
Anyone else?
Steve
Old Nov 20, 2002 | 10:35 AM
Samps's Avatar
could always get a smaller steering wheel. I swapped to the manual rack and it only seems to be difficult in parking situations when you need to make 180s. During normal or spirited driving I kinda like the extra turning distance. But I also have a 350mm steering wheel
Old Nov 20, 2002 | 12:45 PM
j9fd3s's Avatar
Community Builder
you could also take measurements of the rack, and see if there are any hot rod ones that are close.
mike
Old Nov 22, 2002 | 02:26 PM
rxevom's Avatar
Newbie
There are some guys from the Toronto Subaru club that mod 2.5rs/Wrx steering racks for cheep...
Maybe you should ask them about it! Im sure if they have the equiptment for it the racks cant be that different...There both rack and pinion after all!
http://www.rev-lab.com/
there number is there..
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
ZacMan
Sep 19, 2015 09:20 PM
