99 j-spec rims
99 j-spec rims
ok im a newbie here at rxtclub.com, so if this has been asked or answered before dont flame me too much. i am very active member at www.mx6.com . im wanting a set of 17" rims but i stil want the mazda logo. ive called a few local mazda dealerships, but to no avail, they have nothing. i asked about the rims at mx6.com and i was told that there is a 99' jspec rim for the rx7. i have a 94' mx6. could someone point me in the right direction, what site, places do i need to check out about ordering these rims. and will they even fit? thanks for your time.
Brandon
Brandon
Try this site http://laujesse.tripod.com/
He Posts on the form alot
thanks for that site. i emailed him bout it. if anyone else has any info to offer id appreciate it. anyone know what the cost might be? if they even will fit at all......
Brandon
Brandon
I believe the stock offset for the Mx-6 was +40mm. The FD wheels are +50mm. This will push the centerline of the wheels 10 mm into the car.
I'm not sure how wide the stock MX-6 wheels are but I could foresee a width problem with the 8 and 8.5 inch FD wheels. The wheel might not clear some of the brake/suspension parts.
I don't know how universal center cap sizing is but you may be able to just stick Mazda centercaps on whatever wheels you select. You might have to do some paint matching though.
ok yeah, now i remeber hearing about that. i was told spacers would work that out just fine. ive also seen an mx6 with 17"x8.0" and he said that he didnt have any problem with the wheels rubbing anything. ill have to talk to him a little more. thanks.
Brandon
Brandon
I have US FD rims on my MX-6 and they fit without spacers, it's tight though. BTW, the offset is distance from the center of the rim, so you can only really compair offsets if the rim width is the same. MX-6 rims are 6.5" wide with a -45mm offset and FD rims are 8" wide with a -50 mm offset, this will put the inside edge of the rim ~1" closer to the struts. The 8.5" J-Spec will not fit without spacers. Also the narrowest width tire I could get to fit within the tire specs was 225mm, anything narrower and you'll be outside of the recommended rim size.
Trending Topics
Brandon696, If the US spec FD rims fit then you can get 4 Jspec front wheels which are 17x8 with 50mm offsets. I would like to get 4 rear Jspec wheels which ar 17x8.5 for my FD but corksport or any other retailer will not seperate them. Lemme know if you want to work something out.
check this link for more info https://www.rx7club.com/forum/showth...hreadid=122440
what do you mean? theyll sell them to you as like a bulk buiy type deal? send me a PM or email me at xtrememazdaspeedster@yahoo.com. thanks everyone for your help. i checked that link out too thanks.
Brandon
Brandon
Brandon, what he's trying to say is you need 4 17x8 wheels. He wants 4 17x8.5 wheels. The jspec set for the RX-7 is 17x8f and 17x8.5r, so you each buy a set and swap. Since your friend has already fit 17x8, you can too, although you may need spacers.
I have US FD rims with bridgestone S-03 225/45R16 rubber and they fit without spacers, but the rear is very close (I can't slip a finger between the strut and the tire). A different tire or even a different aspect could rub, although 5mm spacers would solve that. The front has a lot more room than the rear and shouldn't be an issue.
BTW, I was informed from Jason @ jt-imports that 99 spec rims would only cost $200 if you were to walk into a japanese junkyard and pick them up
and then cost roughly $300 to ship over. He's as honest as they come, so i wouldn't doubt that very much. The only catch is that there aren't too many wrecked '99 FD's (most swap out the stockers before they total their car)
...just so u know....
-jerry
and then cost roughly $300 to ship over. He's as honest as they come, so i wouldn't doubt that very much. The only catch is that there aren't too many wrecked '99 FD's (most swap out the stockers before they total their car)...just so u know....
-jerry
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
