ignition switch won't stay on
Old Oct 28, 2002 | 12:51 AM
brownmound's Avatar
Anytime baby!
Ok so it seems as if the Mound knows that I just replaced the fuel filter and ordered a new RB exhaust for it. Cause just tonight I got in and went to start it. It will start fine but there is a problem with the switch. When I release it, it will not stay in the ON position, so the car immediately dies. It just won't lock on and stay there.
I should have seen the warning signs, as of late it had been sticking far forward on startup and the BRAKE light would stay on.
So the switch is toast? How do I go about replacing/rekeying one?
Right on.
Old Oct 28, 2002 | 01:28 AM
djmickyg's Avatar
it might just be sticky? try spraying some oil in it, like WD40 with that little fine sprayer to get right into the key hole.
Old Oct 28, 2002 | 07:47 AM
EL PAALO's Avatar
If you need one, we've probably got one.
Old Oct 28, 2002 | 08:05 AM
knight1976's Avatar
yea they got everything
Apoc3D
Sep 5, 2015 10:24 AM
