WOW!!! 35psi oil pressure at idle at temp, could this cause a power loss....
Old Oct 25, 2002 | 10:42 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
I live in minnesota, it has recently dropped in temp here dramatically, average is 30F a day and dropping.
My oil pressure has shot up, (at temp) 35 at idle and 70+ by 1700 it starts with ease every morning though.
anyways, could this cause a noticable power loss. My friend was telling me my car is way slower than it was in the summer. I had somewhat noticed.
what kind of weight should I be running in this temp.
Old Oct 25, 2002 | 11:16 AM
85RX7GS's Avatar
Well, naturally, the oil pressure will be greater in cold weather, during warm-up. As far as the oil weight, 10W30.
Old Oct 25, 2002 | 11:21 AM
do you think it could cause this loss of power,
I was also thinking to check that little filter in the carb, i bet its never been changed.
Old Oct 25, 2002 | 11:26 AM
85RX7GS's Avatar
No, it wouldn't cause a loss of power. The fact that you HAVE pressure is good. Check your fuel or ignition system for power loss.
Old Oct 25, 2002 | 02:30 PM
1rx7owner's Avatar
Lifes a garden dig it.
mine sits at about 40psi at idle after its warmed up and driving around sits aat about 80psi. I would think that sounds normal.
Old Oct 25, 2002 | 03:05 PM
82transam's Avatar
Never Follow
Yea, its normal, mine varies between 30-40 depending on the temperature.
Old Oct 25, 2002 | 04:11 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Well at 750 idle its like 20 or so, go to about 1500 and its almost 50 ... So its not a bad thing, but I do wanna argue the point of oil weight versus pressure Who wants to start first?
Old Oct 26, 2002 | 12:12 AM
Hmmm, Its really cold here right now, wouldnt that cause it to run a little lean. I have stock jetting with all my mods (sig) so its allready running lean.
thats probably it.
whatever, its going in storage in 4 days for the blown 13b to go in.
Ohh, and I fried my clutch today. It shakes alot now.
I was showing off to my girlfriend by pulling a bootleg turn at 50mph.
I ended up going backwards at about 15mph with my rear tires moving at about 50.
kuhmos smell funning when turned to smoke.
Old Oct 26, 2002 | 12:22 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
mines55@ idle and 85 when above 2k
andyvideopro
Aug 20, 2015 10:55 AM
20B Forum
Aug 18, 2015 02:46 PM
