Twin Intercoolers?
Old Oct 21, 2002 | 11:44 PM
Sammymatik's Avatar
Twin Intercoolers?
Ok,
just about got all the stuff to turbo my 12a....
Now I know the motor is realatively small... but I plan to build it with all race parts to allow for higher sustained RPMs.
I don't have the low compression rotors, so I'm wondering if I do go with a large turbo, would having two intercoolers make much of a difference?
I'm just wondering because I happen to have two intercoolers...
Would this really make a big difference in cooling the intake charge? ANd would it allow me to run higher boost pressure with less fear of detonation?
Thanks for your opions
Old Oct 22, 2002 | 04:14 AM
maxcooper's Avatar
WWFSMD
In series, it seems like a bad idea because it would be restrictive for the amount of cooling you get (i.e. one bigger IC would flow better and cool the same).
-Max
Old Oct 22, 2002 | 09:47 AM
KenA's Avatar
Two words, Pressure Drop...
Tried it on a Supra, Doesn't work...
Old Oct 22, 2002 | 10:40 AM
Sammymatik's Avatar
yeah I thought it might be more restrictive than the cooling would be worth, thanks for the advice. Well... I got an extra intercooler....
Old Oct 23, 2002 | 01:29 AM
maxcooper's Avatar
WWFSMD
Try running them in parallel if you have room. Less pressure drop, less velocity allows more time to cool, etc.
-Max
ls1swap
Jun 3, 2024 03:25 PM
