help, no boost but hear turbos spooling
Old Oct 21, 2002 | 09:04 PM
JUSTgotMINE's Avatar
I just got my car back and on the way home from the shop I heard a "pop" from the passenger side and then I got no boost. I'm going to call the shop tomorrow, but wanted to see if was an easy fix so I don't have to take it back. I hear the turbos spooling, but no boost. Did I bust the y-pipe or a hose? I checked the map sensor ...it's ok.
Old Oct 21, 2002 | 09:14 PM
BicuspiD's Avatar
Infamous...Butcher...
OK ill try
Intercooler pipe popped off, or the coupler from the Y-pipe to the IC Inlet tube (flat black tube) was breached
Old Oct 21, 2002 | 09:24 PM
drewroman's Avatar
meh...
Originally posted by BicuspiD
OK ill try
yeah... what he said... it's probably pretty a pretty obvious one too...
I forgot to tighten up the hose going to the intake elbow the other day and as soon as I got on it... POP! and no boost...
good thing all it took was a screwdriver to fix and she was all business after that!
Old Oct 21, 2002 | 09:51 PM
well the hose is on....maybe cracked it. Any other ideas?
Old Oct 21, 2002 | 09:57 PM
7-sins's Avatar
thats not paint....
It has to be in the intake line. PULL OFF!! the coupler from the Y-Pipe to the IC's and check for cracks. You might not see it while its on the car.
Hope it helps,
Chris
Old Oct 21, 2002 | 10:21 PM
is the only upgrade to that the efini y pipe?
Old Oct 21, 2002 | 11:23 PM
Flyrx7's Avatar
Money Pit
That would definetely help. More than likely you popped the coupling at the Y-pipe and crossover tube. Like someone mentioned you may not be able to notice it while it is on the car. Take this coupling off and look at it closely (pull and stretch it while inspecting it)
Frank
Old Oct 22, 2002 | 12:00 AM
7-sins's Avatar
thats not paint....
Frank
Exactly, it probably is the coupling, 10$ if not less. I would go with a silicone replacment so it wont happen again.
Old Oct 22, 2002 | 01:03 AM
r0t0r-rooter's Avatar
call me Smokie Smokerson
I like what i read on the forum once:
Take a wet/dry vac, stick it in 1 of the intake pipes, plug up all the other hoses that connect to the intake with tennis *****, etc. Set that thing on blow and listen/feel for where the leak is.
Old Oct 22, 2002 | 09:36 AM
Can I get silicone couplers from the local auto parts store like napa or advance?
Old Oct 22, 2002 | 01:44 PM
7-sins's Avatar
thats not paint....
You might find it there, I didnt, we have some shitty pepboys and advance though. You can order offline or since PFS was right next to my house I went up there and got one. You could also try any performance auto shop. Make sure its the problem before you get it though.
Old Oct 22, 2002 | 06:02 PM
FYI, I took it to the shop and found out that it was a stuck prespool actuator.
Old Oct 23, 2002 | 01:21 AM
7-sins's Avatar
thats not paint....
Not doubting you or anything but woudln't a suck pre-control actuator give you a boost pattern more like 10-3-8?
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Wolf_
Aug 11, 2015 04:23 PM
