next mod what should it be?
Old Oct 21, 2002 | 09:00 AM
I am getting a act s/s clutch and lightened flywheel installed on my car this week and i am ordering the power fc w/ commander as well as exhaust, downpipe, and I am builiding my own intake. My next question is what should I do next. I am gonna go single turbo but this is my first rotary and so I am wondering what you guys think should be the next mod on my fd. Thanks for the advice.
Old Oct 21, 2002 | 09:04 AM
turbogarrett's Avatar
0 lbs of boost
intercooler and then a highflow cat or midpipe
Old Oct 21, 2002 | 09:48 AM
sszablya's Avatar
Model photographer!
Get a more efficient intercooler. For the amount of mods you have, an intercooler would be the next logical upgrade.
Old Oct 21, 2002 | 09:55 AM
rbrtech's Avatar
Also if your going to upgrade to a bigger turbo you should port your engine
Old Oct 21, 2002 | 09:57 AM
ttpowerd's Avatar
HARRRRRRRRR
you do know that you will not be able to use the downpipe with the single turbo right?
Also, most single turbos make you get rid of the airpump so you will not be able to use a catalytic converter. Go with a midpipe and make sure you get a good intercooler that will work with a single turbo.
You know what you want to get, work your mod list around that so you don't have to buy and sell parts a lot.
Old Oct 21, 2002 | 09:59 AM
ttpowerd's Avatar
HARRRRRRRRR
That is a very expensive step that most wait till they blow the engine for. I agree that it is important and should not be overlooked but you should not spend the money at this point unless your engine is about to go (ie. high mileage, bad compression, etc.)
Old Oct 21, 2002 | 10:17 AM
Vintage Red Touring's Avatar
Don't forget about upgrading your fuel pump! With increased air flow and higher boost you will need more fuel.
Old Oct 21, 2002 | 10:55 AM
2 words, turbo timer
Old Oct 21, 2002 | 11:12 AM
Mahjik's Avatar
Mr. Links
1 word, pointless...
Old Oct 21, 2002 | 11:13 AM
OptusX4's Avatar
Oh, and I'd say an upgraded radiator, never can run too cool.
Old Oct 21, 2002 | 11:27 AM
i cant remember if it was you but i dont like sitting in my car for 2 mins while i let it cool down. if your like me and stay up to late and watch all the infomercails then you will know what this means. i like to set it and forget it
Old Oct 21, 2002 | 11:33 AM
OptusX4's Avatar
The cooldown activity that you describe is the exact same as a turbo timer, which is pointless. I'm inferring that Mahjik is talking about the fact that you should just run your car easy the last couple miles of your drive. Letting it sit still and cool down only promotes heat soak and increases engine bay temp. Whereas, not getting in to boost, and having large amounts of cool air running through the bay is much more effective.
Old Oct 21, 2002 | 11:34 AM
Mahjik's Avatar
Mr. Links
You don't need to idle the car that long. Just stay off boost a little before you get home, idle the car for about 30 secs or so then shut it down.
There is a post back in the archives where an engineer was stating the reasons why turbo timers are pretty much useless.
Old Oct 21, 2002 | 11:35 AM
Mahjik's Avatar
Mr. Links
DOH! OptusX4 beat me to it..
Old Oct 21, 2002 | 12:41 PM
RotaryKnight's Avatar
I dont' think turbo timers are pointless since sometimes you don't have the time to or the situation won't permit your own time to cool down,
BUT I don't see spending $879892442 on a turbo timer that shows your revs, battery life, 1/4 time, geneva time, outside temp, tide level, moon phase etc.
I always believed in getting the cheapy HKS one that was JUST a timer.
As far as next upgrade I think you need a FMIC more than a turbp timer. Then get rid of that cat.
Chris
Old Oct 21, 2002 | 02:01 PM
apneablue's Avatar
and I thought my turbotimer was the only one that displays the moon phase and tide levels
Old Oct 21, 2002 | 03:19 PM
OptusX4's Avatar
Old Oct 21, 2002 | 03:22 PM
RyanREX's Avatar
Killer Turbo Twins
Hey guys! I like my turbo timer. It's also a great conversation peice.
Old Oct 22, 2002 | 11:24 AM
apneablue's Avatar
Originally posted by OptusX4
You know...after buying that HKS TurboTimer with all the options I battled with a place to mount it and ended up setting it and stuffing it under the dash...all the extra dough for featuers that I never used...if you do get one just get the basic and save your money...
IC question...I also would like to go single some day...what IC would would work with the twins and also with a big single?
Old Oct 22, 2002 | 11:44 AM
dubulup's Avatar
development
I bought the type 0 and just use the auto, usually just runs the car about 22 secs...just enought time for me to be walking away and smile at the person that says "Hey! Your car is still running"
demetlaw
Oct 2, 2015 06:22 PM
musker
Oct 1, 2015 05:58 PM
