S5 Parts Price Check
Old Oct 20, 2002 | 04:19 PM
$150FC's Avatar
Currently Winning
How much would you guys pay for the following?
S5 ECU
S5 Engine Wiring Harness
S5 Knock Control Box
S5 Boost Sensor
Just wondering. I've got a couple different sources, but I really don't know how much they're worth and therefore how much I should pay for them.
Old Oct 20, 2002 | 04:28 PM
ZachSpazz's Avatar
I wish I had a posse...
Re: S5 Parts Price Check
S5 ECU
S5 Boost Sensor
TII I'm assuming, right? I would offer $100 for the ECU, $200 for a nice, flexible harness, $25 for the Knock box and $15 for the sensor. Since S5 TII parts are much harder to come by, there obviously is a higher price attached to them.
Old Oct 20, 2002 | 04:29 PM
$150FC's Avatar
Currently Winning
Er Whoops, yeah. S5 TII. Thanks, Zach.
Old Oct 20, 2002 | 04:53 PM
hypntyz7's Avatar
actually those prices are slightly on the low side for what I see them going for.
ecu $150-200
harness $150-250
boost sensor $40-50
But youre right, theyre VERY hard to come by, thus the high prices.
Old Oct 20, 2002 | 05:45 PM
$150FC's Avatar
Currently Winning
I'm wondering if the extra 20 hp and better wastegate are really worth it in terms of parts, heh. I could just as easily get an S4 setup. Less hassle. I wouldn't need a new flywheel, either.
A side note: Kevin, I almost feel like I should give you something in exchange for your N/A->TII rightups on your website. Thanks a lot for them.
Old Oct 20, 2002 | 10:38 PM
hypntyz7's Avatar
No problem. I posted those due to their FAQ status and lack of a clear answer anywhere else. IT's be nice if a lot of people on here bookmarked these links and spread them around later...
Old Oct 20, 2002 | 10:48 PM
Wankel Traitor
out of these few items, the ECU is probably the easiest to find. not a whole lot of boost sensors floating around unfortunately, i see at least a few threads a week with someone looking for it. As far as an IN TACT wiring harness, good luck with that one. It sucks that they are all so old and brittle, and have been modified.
Jameson
Old Oct 20, 2002 | 10:52 PM
cant u turn the NA harness into a T2 harness by moddifying the VDI and 6 ports plugs?
fjwheeler
22
Jan 9, 2022 01:02 PM
