What are the indications of a slipping belt?
Old Oct 19, 2002 | 11:42 PM
SPDSTR 7's Avatar
Old Oct 19, 2002 | 11:54 PM
KNONFS's Avatar
B O R I C U A
You'll see the Volt needle droping while the RPM increases........
Old Oct 19, 2002 | 11:57 PM
SPDSTR 7's Avatar
Hmmm. I don't notice that though but I get hesitation on higher RPMs.
Old Oct 20, 2002 | 12:01 AM
KNONFS's Avatar
B O R I C U A
Sounds like closed 5&6 ports........ Was it like if you stoped pressing the gas all the way? Did you felt the car not amking power around and above 6k rpms? Or was it just hessitation, like if the car was flooded?
Old Oct 20, 2002 | 12:05 AM
SPDSTR 7's Avatar
It's hesistation because my car's power goes up and down. If you were to put it on a graph, it will look like a wave.
Old Oct 20, 2002 | 12:09 AM
KNONFS's Avatar
B O R I C U A
Hmmm, that doesn't sound like a 5&6 ports problems. Have you messed with the SAFC lately?
Try to test the car without the ignition amplifier box...
Old Oct 20, 2002 | 12:12 AM
SPDSTR 7's Avatar
Yup, just trying to lean it out a little. I thought it was my setting too but I set everything back to 0% and the hesitation is still there.
Old Oct 20, 2002 | 12:21 AM
KNONFS's Avatar
B O R I C U A
Here is my experience with my untune SAFC, when I did the installation I rook the car for a test drive, everything seemed to be fine TILL I hit 6K rpms in first gear. I encouter some MAJOR hessitation the first time I took first gear all the way to redline. Afterwards, the hessitation was gone on first gear; however same thing happened right after I wined upo 2nd gear.
I believe (and this might be the stupidest thing you have ever heard), that the SAFC takes some time to "Learn the car characteristic".
After I experienced hessitation on first gear (just for the first time I tried to red line it), it happened the same thing on second gear, and then on third gear; the hessitaion was noticeable on hig rpms +6k, but not on the same exact spot on each gear.
I might be way off though.......
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Robrods64
Oct 2, 2015 07:56 PM
Turblown
Sep 30, 2015 05:58 PM
Farkel
Sep 16, 2015 06:16 PM
