End play worries
Old Oct 17, 2002 | 01:12 AM
88 SE's Avatar
End play worries
All this reading about dropped bearings has raised a few questions.
I have the engine fully assembled, but in cant move the ecc shaft back and forth at all. Form what i read its supposed to have a very small amount of play?
I dunno how it would be wrong, i assembled the engine with all teh same components and made sure the bearing didnt drop
Old Oct 17, 2002 | 12:22 PM
Hot_Dog's Avatar
Re: End play worries
The e-shaft end play should be approximately 0.001" to 0.002". The only way you'll be able to detect this small amount of end play is with a dial indicator. If you reused the original thickness spacer, than should be within spec provided that your thrust bearings are ok. The FSM has a procedure to verify whether or not a bearing has dropped during assembly. The FSm says that you need to measure distance between the inside bore of the front pulley and the end of the e-shaft. If the measured gap does not meet the specified value, than the bearing may have dropped.
Hot_Dog
'90 RX7 GXL
'02 RSX-S
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
firzen
Sep 15, 2015 12:04 PM
