heater control question?????
Old Oct 16, 2002 | 12:58 PM
fastassturbo2's Avatar
hey guys my girlfriends rx7 she has an 88 se her heat does not work, well i think the logicon is not working becasue of course the high and low no air comes in or anything plus i might be suspecting the heater blower doesnt work? now if you guys can give me your two cents i would gladly apperciate it, and if it is one of those two can sumone sell me any of these items
thankx
amir
Old Oct 16, 2002 | 01:39 PM
RETed's Avatar
If it includes vent location, it's most likely the AC Logicon.&nbsp If it's heat isolated, it could be just the air mix motor.&nbsp Resoldering of the AC Logicon is pretty straight-forward, except there are a LOT of soldering points inside the unit - concentrate on the main harness plugs and the faceplate IC board.&nbsp Removal of the unit from the dash is a bit complex, especially for the first timer.&nbsp If it's just the air mix motor, it's a remove and replace affair under the dash.
-Ted
Old Oct 16, 2002 | 02:13 PM
thankx ted by the way remeber the haltech problem i had with my car u like helped me through it well it turned out to be the motor!
thankx again bud
Old Oct 16, 2002 | 02:38 PM
i am not getting anything from the vents at all even if you switch back and fourth to where the heat or air comes from! so like i was thinken its the logicon! if so it is then i thought there was a write up on how to solder it and etc, by the way ow the hell do youget that third plug that goes to the main harness in the car? take out the speedo cluster out? any hints would be apperciated
Old Oct 16, 2002 | 02:39 PM
RETed's Avatar
Aw, that sucks!
-Ted
Old Oct 16, 2002 | 02:45 PM
RETed's Avatar
If you want that cable out, there are two ways to get at the plug.
1) You need to remove the plastic cover on top,center of the dash; remove the single bolts/screw under it - you should be able to remove the metal panel now&nbsp Be warned, the plastic vent pieces are going explode and turn into tiny pieces of plastic when you distrube them.&nbsp Once the metal panel is removed - you'll see the plug in the center, mounted vertically.&nbsp Unplug and pull through...
2) Some say you can actually snake you hands from under the dashboard to remove the plug.&nbsp I have never done this myself.
Otherwise, there's another option - pop the AC logicon open and unplug the wiring harness from the IC board.&nbsp This leaves that harness inside the car, and lets you take the rest of the AC Logicon with you...
Once you get the AC Logicon out, concentrate on the main wiring plugs, where they meet the IC boards.&nbsp Also, redo ALL the solder joints on the face plate IC board.&nbsp This will solve the problem 90% of the time.
-Ted
Old Oct 16, 2002 | 03:04 PM
dam ted your awesome bud thank you so much for the help! nowi get to use my $50 solder iron and solder i bought for my wolf install that i never got to put in i sold all myshit and i even ahve a nice rebuilt 13bt motor that i am tryen to sell, but anyhow thankx again
amir
Old Oct 16, 2002 | 03:22 PM
RETed's Avatar
Good luck!
-Ted
Old Oct 17, 2002 | 12:28 PM
thankx ted, i did find out the prblem and i soldered the wire that had a short! but anyhwho, the peeps who wanna unplug this connector all you gotta do is remove the gauge cluster i found that to seem alot easier!
take it easy guys and good luck!
turbo-minivan
69
Feb 4, 2016 12:29 AM
rexhvn
Aug 19, 2015 02:59 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
