Lights on the right side
Old Oct 13, 2002 | 05:08 AM
Lightbulb Lights on the right side
Hi guys, first time posting here. I have an 84 gsl-se. The lights (both front and back do not come on), however the headlight does come on when I switch it onto full beam. Does anyone have any ideas about what might be wrong? I though it might be one of the relays but I really have no idea where to start from.
Old Oct 13, 2002 | 07:34 AM
85RX7GS's Avatar
Sounds like the contacts are dirty. To clean them, you'll have to pull the turn signal assembly off.
Old Oct 13, 2002 | 08:27 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Re: Lights on the right side
VERY VERY common problem, you need to take the cluster assy out from behind the steering wheel and spray it out with contact cleaner... If you do a little search you will see a few others that had the same problem... My car was one of them
Old Oct 13, 2002 | 04:26 PM
Thanx afor the info. Much obliged.
Old Oct 13, 2002 | 04:28 PM
Manntis's Avatar
add to cart
that's what this forum is all about @ least the 1st gen section...
Jutta_J
Mar 25, 2017 11:24 PM
tsmith94FD
Aug 16, 2015 05:41 PM
