Turbo, Boost?
Old Oct 13, 2002 | 03:31 AM
Angry Turbo, Boost?
Hey, Im still very new to the forum and the RX-7 and was wondering what everyone is talking about when they say boost, 7psi, blah blah.
I mean can someone explain how boost works?
is it better if its lower higher?
Thanks
Phil
Old Oct 13, 2002 | 04:42 AM
PsToNs SuK's Avatar
The higher the boost the better. But it all depends on what you have modded on the car. Stock you should run, I believe, around or at 10psi. After that I couldn't help ya.
Old Oct 13, 2002 | 06:57 AM
Fd3BOOST's Avatar
Recovering Milkaholic
Boost is what is generated by turbos. Boost is generally measured in PSI=Pounds per squre inch. Stock 3rd gen's or Fd's as most of us call them run 10psi boost. The higher the boost levels the faster the car will go. It's a litte more involved than that but it's a basic description.
go here and do some research
www.rx7turboturbo.com/robrobinette
then here..
www.scuderiaciriani.com/rx7/
Old Oct 13, 2002 | 07:49 AM
rxrotary2_7's Avatar
get a book written by corky bell called maximum boost. that will explain A LOT. actualy maybe MORE than you will need.
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
