Skidpad?
Old Oct 10, 2002 | 06:36 PM
Skidpad?
Whats the skidpad on a 1st gen rx7?
Old Oct 10, 2002 | 08:17 PM
851stgen12a's Avatar
Off riding sportbikes!
I do believe .89G's. I think I read that in an old Motor Trend article. so It might be wrong but I dunno.
Old Oct 10, 2002 | 10:19 PM
genrex's Avatar
Two years ago, I looked at an old (1984?) Road & Track review, and I think it said 0.79 or so. I almost laughed out loud in the library!.. most of us could top that in a stock RX-7 if we have skidpad or autocross experience.. or natural ability.
I wouldn't be surprised at 0.89, with good tires and etc.
Old Oct 10, 2002 | 11:12 PM
RacerX7fb's Avatar
paradox
Car and Drivers review for the GSL-SE on a 200 foot skidpad is .82 yeeeek
Old Oct 10, 2002 | 11:21 PM
peejay's Avatar
Old [Sch|F]ool
Depends on what kinda tires you have.
Old Oct 11, 2002 | 12:16 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
And a lot of other things
Old Oct 11, 2002 | 01:55 AM
RotorMotorDriver's Avatar
Seven Is Coming
What is skidpad anyway? I always wondered when reading stuff about cars, lol. I feel so un-educated .
~T.J.
Old Oct 11, 2002 | 02:25 AM
ioTus's Avatar
'84 5-letter
So far as i can tell, its a professoinal and sophisticated form of "taking-that-25mph-at-80-and-seeing-how-you-do".
Old Oct 11, 2002 | 06:24 AM
Seven Is Coming
Oh...lol. Ok .
~T.J.
Old Oct 11, 2002 | 07:04 AM
peejay's Avatar
Old [Sch|F]ool
Yeah, you have a big flat smooth surface about 200" in diameter or so, and you go around it as fast as possible before the car can't maintain the circle painted on the road. G force can then either be directly measured, or calculated from how quickly you orbit the circle.
There's no transient change at ALL in a skidpad, the only part the suspension plays is how much roll stiffness the car has in the front vs. the rear determining if the car ultimately understeers or oversteers at The Limit steady-state. It pretty much tells you how good the OE tires are.
For example, the only difference suspension-wise between a GSL-SE and a "regular" RX-7 is that the GSL-SE had slightly wider, much grippier tires on it, and differently tuned front strut dampers. That's it. The big increase in grip (.92g i think vs. mid .80's for std RX-7) is entirely due to the tires, since dampers do absolutely nothing in steady state conditions.
Same thing for R1 F vs. base/touring. The R1 had much better skidpad numbers. Only differences were tires, and stiffer shocks... again the spring rates etc were the same.
My gut feeling is that Mazda tinkered with the dampers on both cars because sticky tires and soft shocks are a bad combination, they can force the suspension to move too fast if you drive like a dumbass and it generally feels bad regardless.
Keep all this in mind when ou buy new tires... put some Super Gummy tires on your car (you know, the ones with treadwear ratings around 00 that can allow your car to corner at well WELL over 1g) and you might find that you can maneuver so quickly that you can momentarily bottom the suspension at the exact moment you don't want to...
Old Oct 11, 2002 | 07:12 AM
Seven Is Coming
Woah. Thanks for the great answer PeeJay .
~T.J.
Old Oct 11, 2002 | 07:40 AM
peejay's Avatar
Old [Sch|F]ool
No prob.
I find it funny when people brag about their skidpad numbers for a stock car, when they have the cheapest tires that would fit on their rims, usually BFGoodrich's which the street tires are greasy nasty piles of dung...
Also the skidpad numbers are dependent on tire pressure... add or subtract presure and the figures can and will change...
And the skidpad number has nothing to do with handling. A car can handle so bad it's scary to drive, but the skidpad numbers are astronomical. I had a car like that once... I put on Big Huge Tires and dialled in almost 3 degrees of negative camber in the front tires. Did nothing about spring rates, roll centers, bumpsteer, dampers, anything. It'd corner extremely hard (judging by cornering speeds, about the same as my '80 cornered with DOT-R tires on it - better have your seatbelt on TIGHT and you still have to hold yourself up with the seat/door) but the chassis dynamics were worse than appalling - snap understeer, snap oversteer, scary corkscrewing motions if the corner had any bumps at all... that was the only car I ever spun off the road.
I really miss that car....
gnx7
V-8 Powered RX-7's
31
Jun 3, 2025 10:08 AM
ConePirate
West RX-7 Forum
Jan 29, 2010 07:45 AM
uptotibet
Sep 19, 2008 07:58 PM
gnx7
Race Car Tech
53
Jun 10, 2005 05:48 PM
JoeD
Jan 25, 2002 05:15 AM
