running rich, smoke at start up
Old Oct 8, 2002 | 09:38 PM
Stevey629's Avatar
Rotor Shaped Blood Cells
sup guys, just wanted to ask if any of u guys knew about why my car might be running rich...I have a 93 touring, with 87k on it, and it just smells like its runnin rich from the exhaust. Also, the exhaust excessively smokes white when I first start it and drive for the first 5-7 mins or so. I know these cars are supposed to burn oil, but that much? or is it coolant? if u could help me possibly diagnose this that would be greatly appreciated.
Old Oct 8, 2002 | 09:48 PM
Mahjik's Avatar
Mr. Links
Normally, you should get a little smoke at start up (depending on how long the car has sat without being driven). However, it shouldn't last long.
First thing, check the smell of the smoke. See if you have a hint of coolant smell in the smoke or not.
If there is no coolant smell, then check the oil lines for the turbos and then have the turbos themselves checked out.
Good luck.
Old Oct 8, 2002 | 11:32 PM
Stevey629's Avatar
thanks for the input...Im not really sure exactly what coolant is supposed to "smell" like though...at least when it burns.
Old Oct 8, 2002 | 11:55 PM
Snook's Avatar
Tony Stewart Killer.
it has a sweet smell
you will be able to tell the difference between coolant, oil or gas
Old Oct 9, 2002 | 12:28 AM
Stevey629's Avatar
thx snook. I know the car smells like gas when it first starts up as I was saying earlier...it basically smells like unburned gas. But later as I drive, theres white smoke. And quite a bit of it... I can see it from commin off the back of the car from my rear view mirror. I guess I should go out and take a sniff when that happens. But after a few minutes of driving, it all dissappears, and is just hot by the exhaust.
Old Oct 9, 2002 | 12:34 AM
evel333's Avatar
Re: running rich, smoke at start up
iginally posted by Stevey629 [/i]
Also, the exhaust excessively smokes white when I first start it and drive for the first 5-7 mins or so. I know these cars are supposed to burn oil, but that much? or is it coolant?[/QUOTE]
White smoke isn't good. Just from experience, my bet is on the latter...
Old Oct 9, 2002 | 12:42 AM
Snook's Avatar
Fuel is black/clear looking when it comes from the exhaust
The white smoke is either oil or coolant. Both are not great indications. From your description it could be either or both. You really need to give us more info about life of the motor and turbos and your mods. Do you have a trusted rotary shop near where you live? I would take it there and get a free inspection...it should be really obvious for them since they are right there with the car.
I hope this is something very small
good luck
Old Oct 9, 2002 | 01:42 AM
Stevey629's Avatar
my car is stock...its compression is a bit low, Im not sure what it is though. there is a place that I can take the car, and I think Im going to take it there within the next week. Hopefully they'll know what it is right away. I just hope to God its nothing big.
Old Oct 10, 2002 | 05:47 AM
Alejandro's Avatar
My car is also stock with 52.000 miles, my compression is good and the color of the smoke is hard to tell but it also smells like unburned gas.
Could it be the turbos how could I tell if they are bad?
The only way to tell will be with a boost gauge?
Thank you in advance,
Alex Kuipers
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
pzr2
Aug 15, 2015 08:29 PM
