Apex seals
Apex seals
Ive got a 94 13B with 3mm apex seals in it, i was wondering it 3mm seals made more noise than 2mm seals? My motor is not loud, but I can hear the seals brushing the housings.
Chris
Chris
usually if you can hear the seals the housings are bad, or its possible you are hearing the compression bleed between chambers and have a bad seal. how old is the motor?
mike
mike
I've never heard of anyone that said they can hear their apex seals. On a piston engine you can hear rod nock or the valves ticking. Maybe its an exhaust leak your hearing.
Snook
Oct 8, 2015 10:09 PM
