nitrous express????
Old Oct 6, 2002 | 08:32 PM
nitrous express????
i saw in the october issue of super street hat 1 of the skylines had a nitrous express kit on it. dose NX run through the intercooler and make the air even colder there for giving you more hp? please tell me how this works. also, whats thier website?
Old Oct 6, 2002 | 08:34 PM
allrotor93's Avatar
n-tercooler
it cools off the fins of the intercooler making more power. the kit is about $370. not too bad ad it also looks cool.
Old Oct 6, 2002 | 08:40 PM
boostedyellow7's Avatar
they say on a turbo honda it made 50 xtra hp?
Old Oct 6, 2002 | 08:47 PM
some guy on mustangworld is selling one for 300 bucks shipped.....yeah it sprays nitrous on the intercooler making it cooler, u can also put CO2 in there for cheaper i believe
Old Oct 6, 2002 | 08:56 PM
nocab72's Avatar
03 Cobra Killer
Just becareful you don't suck too much up your intake after it passed through your intercooler, go lean and BOOM. I would suggest testing with CO2 cause if you stuck that up, you'll go rich and avoid the big BOOM.
k
Old Oct 6, 2002 | 09:52 PM
i had no idea that it sprayed, i thought it made that oval bar cold and the air travled fast that making the air cold and hiting the intercooler. spreaying onto the intercooler makes pefect sense now
Old Oct 6, 2002 | 10:19 PM
i believe it doesnt go into ur intake, im almost postive of this, it just sprays nitrous or co2 in the outside of the intercooler, nothing actually goes inot the intake
Old Oct 6, 2002 | 11:50 PM
SUPRAMAN
no it goes in to the ic that's how nitrous works. I have a nitrous express fogger kit. I drilled a hole into my intake pipe and stuck the nozzle in there.
Old Oct 6, 2002 | 11:59 PM
we are talking about the Ntercooler chiller
Old Oct 7, 2002 | 12:49 AM
93redFD's Avatar
I think its complete waist of n20!! And nocab72 is right!! theres a good chance that you will suck n2o in the motor and you will lean out and "what the hell just happened " N2o is only good to help spool the turbo up. You have to be very carefull also becuase turbo and n2o will make the boost go crazy!! if your just spraying it for hp.
Old Oct 7, 2002 | 12:55 AM
They guy was just showing off by shootin nitro out the side.
Old Oct 7, 2002 | 09:00 AM
once again this does not go into your intake because all it does is spray nitrous or co2 on the intercooler, not INTO the intercooler but ON it
Old Oct 7, 2002 | 10:31 AM
SUPRAMAN
i heard it sprays into it. Maybe not.
Old Oct 7, 2002 | 10:38 AM
nocab72's Avatar
03 Cobra Killer
BELIEVE ME and LISTEN TO ME...I have the kit, I'm not guessing!!
The oval bar mounts in front of your intercooler.
N20 (or CO2) sprays out though tiny holes in the oval bar. The N20 being REALLY cold passes through the fins of the intercooler (but not INSIDE the intercooler). This superchilling effect helps drop the temp of the air passing through the INSIDE of the intercooler on its way to your engine.
What I was WARNING about is AFTER the N20 passes through the fins on your intercooler, that air mixed with N20 is going to be IN YOUR ENGINE BAY. If you run an open air intake that sucks air from IN YOUR ENGINE BAY you will most definately suck air mixed with N20 into your open air intake. Now you have N20 IN YOUR ENGINE, you WILL GO LEAN, you MAY BLOW YOUR ENGINE (w/out dumping a **** load of extra fuel).
I know, I saw 18:1 ARF's under WOT when I was playing around and chipped a couple of spark plugs. Thought FOR SURE I blew my engine by the PING/DETONATION sound I heard. Fortunately the dyno driver got off it immediately and my engine was saved (barely I imagine).
So...be VERY careful with this kit.
K
Old Oct 7, 2002 | 10:58 AM
Mahjik's Avatar
Mr. Links
Arrow Re: nitrous express????
http://www.nitrousexpress.com/welcome.htm
Old Oct 7, 2002 | 02:34 PM
93redFD's Avatar
i was told that its spays into the intercooler! but o well. But once agian nocab72 is right if anything goes into the engine ,bag!!. Why not just spay direct into the greddy elbow??? You can run additional injectors , you will also have to get the n2o tunned.
Old Oct 7, 2002 | 03:07 PM
nocab72's Avatar
03 Cobra Killer
Where is the "English MotherF*cker!" pic when I need it...
K
s2k
Apr 10, 2002 08:54 PM
boostedyellow7
Jan 14, 2002 03:32 AM
