CWR kit - pressure
Old Oct 6, 2002 | 06:03 PM
manatecu's Avatar
CWR kit - pressure
Is anyone running a CWR kit with a single? If so what kind of pressure are you getting. I am using a greddy gauge so I am in KG/cm2 but I can convert if you have something else.
I put in a new engine and a new turbo and the oil pressure has gone up. At idle I used to be at 1kg/cm2 but now I am at 3kg/cm2. I have seen the pressure go as high as 9kg/cm2 is this normal?
Thanks
Chris
Old Oct 7, 2002 | 04:18 AM
maxcooper's Avatar
WWFSMD
I assume you are asking about the oil coolers rather than the IC.
Where does your oil pressure gauge pick up the pressure? If it is after the coolers (like the stock gauge), pressure will go up as pressure drop across the coolers goes down. One significant factor may be that you have cooler oil, so it will be thicker and you'll get more pressure. You also have a new oil pump (most likely), and new oil, both of which could pump up the pressure.
-Max
Old Oct 7, 2002 | 02:03 PM
suganuma's Avatar
no
what SHOULD oil pressure be around when everything is fuctioning properly.
what i mean is what is a number that is too high and what is too low?
Old Oct 8, 2002 | 08:36 PM
manatecu's Avatar
At idle I am seeing 40psi and at 7k I am seeing 128 psi I am not sure if this is normal.
Chris
Old Oct 8, 2002 | 09:16 PM
JBC's Avatar
JBC
That sounds normal to me. I don't think I ever watched the oil pressure gauge until after I got the coolers.
13
Jan 9, 2018 11:19 AM
K4B00SS
1st Gen General Discussion
Sep 3, 2015 08:13 PM
