check valves part numbers?
Old Oct 6, 2002 | 03:18 AM
DRAG0NEER's Avatar
Hi all I'm doing the vac hose job next week and I want to change all my check valves. Does anyone know all the part #s for the (4?) check valves under the UIM? Also what else should I replace while I'm in there? FPD? Solenoids? thanks...
Old Oct 6, 2002 | 09:46 AM
Mahjik's Avatar
Mr. Links
Arrow
Download the parts diagrams and look them up:
http://www.mazdaformance.com/rx7parts.htm
Old Oct 6, 2002 | 12:24 PM
GsrSol's Avatar
Z06 powered FD
I think the stock ones are $20 a piece but you can get them at almost any parts store for $2 a pop.
Old Oct 6, 2002 | 12:54 PM
DRAG0NEER's Avatar
thanks for the link mahjik!
GsrSol: from the parts diagram all I see there are the pcv valve and one check valve...is that all I need to replace? I'm pretty sure that there are more than just one check valve under there, can anyone please clarify this? Also, what else should I replace while I'm in there? I have 65k miles thanks.
Old Oct 6, 2002 | 01:33 PM
DRAG0NEER's Avatar
okay it looks like I would need a total of 4 check valves, 2 of each part number. Are all 4 of them identical even though they have different part numbers? And is it really a good idea to pick them up at a regular parts store? Somebody please clarify this...thanks!
Old Oct 6, 2002 | 02:58 PM
GsrSol's Avatar
Z06 powered FD
I thought there were 5 but I could be wrong.
I'm sure the oem valves are better and if you can spare the extra money, get them.
josef 91 vert
23
Sep 3, 2015 11:20 AM
04G35S
Aug 14, 2015 07:31 AM
