Does this sound like a reasonable turbo setup?
Old Oct 6, 2002 | 01:01 AM
-TO4E .60 v trim .96 ptrim
divided/ on center with divided HKS cast manifold
-tangential housing(so wont have problems hitting frame rail)
- i know theres supposed to be specs for the exhaust side,what specs do i need?
sorry if it don't sound right but i searched for 2 hours already.... trying my best to figure out what i want..
Just a turbo that spools quickly making 350rwhp still not sure what the exhaust side means and what the hell does a/r mean?
Old Oct 6, 2002 | 02:00 AM
Scott 89t2's Avatar
SOLD THE RX-7!
hks makes a divided manifold as well??
the .96 ptrim is the exhaust size.
lots of poeple use a 60-1 intake instead of the v trim.
Old Oct 6, 2002 | 02:32 AM
RETed's Avatar
"TO4E 60" (take out the period) and "V-trim" are mutually exclusive.
-Ted
Old Oct 6, 2002 | 02:43 AM
im not sure if hks makes divided, if they dont who does make the divided manifold? i just heard it flows better, and i just wanted a v trim because i read it spools up fairly quick...i went to lateshiftengineering for more info and i seen the t04e and i know now the .60 is for the compressor a/r....what should i use for the turbine a/r?it doesnt list .96....
thanks
I myself still doing searches for the t04 family
Old Oct 6, 2002 | 03:15 PM
Rs4Racer's Avatar
whats the difference between a t04e t04b and t04s ?those are the only t04's i have seen so far.
Old Oct 6, 2002 | 04:39 PM
check this out.. it should help out alot..helped me anyways..
http://www.lateshiftengineering.com/Products2.htm
Old Oct 6, 2002 | 07:29 PM
gsracer's Avatar
EIT
on a full t04 set up (not hyrbid) is a stand alone virtually mandated or is it possible to get by with a bandaid SAFC with 1300cc secondaries and 720cc primaries?
Old Oct 6, 2002 | 07:54 PM
No7Yet's Avatar
Talk to dc350 (Dale Clark, in Pensacola). He's running a full T04 with the stock (S4, even) ECU + SAFC + AIC + MSD + every other TLA there is
Brandon
Old Oct 7, 2002 | 12:10 PM
RacerXtreme7's Avatar
NASA geek
turbo set up
Go with a T04e 60 compressor wheel, .60 A/R compressor housing, wet center, .84 divided tang. (STAY AWAY FROM ON-CENTER HOUSINGS) "P" trim turbine wheel. This will be the exact set up I will be running. Quick spool and good top end with no problems reaching 350 rwhp. Some will say .84 is too small, don't worry, its still MUCH larger then the tiny stock turbine housings and should offer a quick spool and still flow good at the top. Most recommend .96 undivded or 1.0 divided, this will give excellent top and 400rwhp potentual but spool up will suffer. If you do decide to go .96 undivided, your boost will most likely not come online strong till around 3200-3500 rpm,s or maybe later depending on your porting configuration. Turbine housing size is just prefference and what you intend your car to do. For quick spool, which is best for auto cross and street driving go .84 divided. But like I said, with the larger housing you can make more overall power on the top.A/R is aspect ratio of inlet area and radius of the housing. Larger the a/r the more flow, but slower the spool rate. The compressor housing a/r isnt as critical, but larger a/r on the cool side tend to have peakier power delivery.
My $0.02
~Mike..........
Old Oct 7, 2002 | 05:57 PM
who sells a divided manifold?
Old Oct 7, 2002 | 06:01 PM
RETed's Avatar
Both HKS and XS Engineering do.&nbsp Be prepared for the $500+ price tag.
-Ted
Old Oct 7, 2002 | 06:10 PM
-Ted
so can i just use both undivided then?
Old Oct 7, 2002 | 07:50 PM
RETed's Avatar
Sure.
-Ted
Old Oct 7, 2002 | 08:45 PM
Ryde _Or_Die's Avatar
Brandon
Hes running the GReddy e-manage now.
autoxer
21
May 22, 2019 04:07 PM
Th0m4s
Feb 26, 2019 02:04 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
