Bridgeport 12a
Old Oct 5, 2002 | 10:10 PM
hybridracer's Avatar
I Post In The Nude
Bridgeport 12a
Ok so bridgeporting the 12a. What all internals are required. Im going with one peice carbon apex seals, lightened rotors, a weber carb, racing beat header to a straight pipe all the way back, racing beat intake manifold. What else do you suggest, will I need hardened stationary gears? What else will I need to do this right. This is going to be an all track car so it wont be driven on the street and will only be seeing about 2 miles every month, about 8 runs on the 1/4 mile
Old Oct 5, 2002 | 10:21 PM
REVHED's Avatar
Hunting Skylines
Sounds like you have it all covered pretty much.
Old Oct 5, 2002 | 10:29 PM
I Post In The Nude
Thanks, now all i need is about 6k
Old Oct 6, 2002 | 10:22 AM
851stgen12a's Avatar
Off riding sportbikes!
who is going to build your motor??
Old Oct 6, 2002 | 02:01 PM
I Post In The Nude
your looking at him
Old Oct 6, 2002 | 02:06 PM
zYgoTe's Avatar
So you do or do not need hardened stationary gears? And why lightened rotors?
Old Oct 6, 2002 | 02:18 PM
right on. still havent done a rotary rebuild. thinking going to buy a used 12a and give it a try.
By the way does anyone have a 12a they want to give away or sell for cheap??
Old Oct 6, 2002 | 02:30 PM
I Post In The Nude
Thats been my problem, finding the damn car to do this too. But alas, i found some lady with a 80 S here who is going to sell it to me for 550, which is really a rip off cause the thing doesnt run, the paint looks horrible, and the keys dont even work in the ignition, she originaly wanted 750 for it but i managed to at least talk her down to that.
Old Oct 6, 2002 | 03:57 PM
MaTT_FoULk's Avatar
earning these was better
So you can rev to some insane RPM and tap the power of the brideport
Old Oct 6, 2002 | 04:01 PM
I Post In The Nude
HAHA yup, this things going to make some insanse power up in the 8500's.
Old Oct 6, 2002 | 04:49 PM
WackyRotary's Avatar
standard combustion
Yo, bridgeport owner here. Heres mine. Rev's to 9000. Usually never past 8000rpm except when I'm trying to be obnoxous. PS: no stationary gear hardening or mods to the rotors either. Just carbon seals, 93+corner springs. Underdrive pulley for the water pump, fact that it helps power is a bonus.
Old Oct 6, 2002 | 06:40 PM
Defprun's Avatar
Punk Ass Bitch
Would lightened rotors help reliability at all?
Old Oct 6, 2002 | 06:46 PM
metalliman's Avatar
If you plan on revving past 8500 RPM, Racing Beat recommends the use of hardened stationary gears. Also they recommend clearancing rotors, rotor bearings, and main bearings. By the way, stick a 13B oil pump from an -SE on your 12a, it's a direct bolt on, in combination with a oil pressure regulator that goes to 85-90 psi. You may be able to get away without the rotor mods so long as you don't go above 8500+ very often, but I strongly recommend the oil mods myself.
Old Oct 6, 2002 | 07:50 PM
standard combustion
Opps forgot, I do have a 80-85psi oil regulator too.
Old Oct 6, 2002 | 07:54 PM
standard combustion
bridgeport. Note: I spilled some gas on it since then and the paint isn't soo pretty anymore. But thats ok, its whats inside of it that counts.
Old Oct 6, 2002 | 08:03 PM
standard combustion
Enginebay. Ps: that is a pacesetter, but where you see it, you don't see how it ends under the car. I chopped the collector and ran it back to the rear axle and lengthened the short rear rotors' pipe so they are equal were they collect. Biggest hp gain, even over the Weber. Cool sound, kinda loud though.
Old Oct 6, 2002 | 09:05 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Hi WackyRotary, where'd u get those dual air filters from? And, if u don't mind, what jetting are u using on the carb. 48 DCOE, right?
I've got a 12a JBridge coming to my house in 2 weeks and am putting a dellorto on it, and can use some comparison jetting from ur DCOE.
Thanks,
-bp-
Old Oct 6, 2002 | 09:37 PM
Jeff20B's Avatar
Lapping = Fapping
The bridgeport is calling to me!
Old Oct 6, 2002 | 09:53 PM
standard combustion
Actually thats a 50DCO, they have no choke connectionn on it, but that is irreliavent info, but actually I wish I had that here in MN were its cold right now(~40-60F now in Oct). DCOE, has the choke option. The filters are custom ordered ones from a parts store. Any parts store or particularily a performance shop has a full K&N catolog you can get them for or may have one or two on hand(~$25each). I forget the part number. They don't have any breathing problems and apparrently have enough area to remain flowable for a long time. OH, they they "just fit" and I mean barely. 50mm bore and the velocity stack was a very tuff fit. So much infact, I took the little nuts holding the stacks to the carb to pry them on and finshed off with a hose clamp on each. I never intend to remove the filter from the stack again ever. Just pull the stack nuts to clean them some day.
As for jetting, a dellorto will be a different deal. I have 245mains seem to be best for mine, F11 emulsion, ~220air correctors? <=I had to experiment with them to get the best power. I drilled out two pairs of air correctors with very fine drill bits to get the best results with my bridgeport. Weber jets are VERY hard to get here since Mazdatrix CA and the other few out there that even have weber parts.
I wish someone could tell me were weber parts are sold in Minnesota.
Old Oct 6, 2002 | 10:30 PM
Jeff20B's Avatar
Lapping = Fapping
I've got most of the parts I need to go bridgey and a car for it to go into. To keep from hijacking this thread, I started a new one. Check it out and let me know if it's a good idea: https://www.rx7club.com/forum/showth...hreadid=121250
James Knox
Oct 22, 2015 05:08 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
