Buzz
Old Oct 4, 2002 | 09:55 PM
85RX7GS's Avatar
Talking Buzz
Anyone want to know how to disable the door/ignition buzzer?
Old Oct 4, 2002 | 11:04 PM
Stripgear's Avatar
Locate the rectancular box under the dash that contains
the buzzer and remove it from the car. On the box is a round buzzer. Pop the cap of the buzzer and remove the thin metal vibrating disk. Put it all back together and
reinstall. No more buzzer!
Old Oct 4, 2002 | 11:06 PM
Keaponlaffen's Avatar
Take the little wires coming out of the back of the little push-in switches in the door-jambs, and cut 'em off.... done... no more buzzer.... OR light
Jeff
Old Oct 5, 2002 | 02:12 PM
BrianHeston's Avatar
Beware Of Squirrely Wrath
Nah, just duct-tape the button in!
Old Oct 5, 2002 | 02:18 PM
gamble302's Avatar
roadkill hats rock
hey whats up man? your old cars still doin great. cleanin it up little by little on my days off.
i think im gonna go ahead and add a toggle switch for it on my daily driver. sometime tonight i hope....
gamble
Old Oct 5, 2002 | 05:03 PM
85RX7GS's Avatar
Uh....no . The following method is far easier than removing the CPU flasher box. Here's the way I did it:
Take off the steering column surround plastic and locate the ignition key switch. Stick your head around the back and you'll notice a white (may be faded on yours) little box with two wires coming out of it. The wires should be in a black insulator. Follow these two wires down the steering column until you come to all the brown connectors. In the general area, you'll spot a white connector with a green wire and a red/yellow stripe wire connecting to a blue/yellow stripe wire and a green wire. To disable the buzzer, unplug this connection. Success! No more buzzer!
The good thing about my method is that you can restore it back to its original functionality if you wanted to.
Old Oct 5, 2002 | 07:32 PM
Pele's Avatar
Right near Malloy
I removed one screw from teh door switch and put a large washer under it. Then I tightened the screw. If I want the light, I'll turn it on myself. If my passenger door is open, I wanna know.
Old Oct 5, 2002 | 07:38 PM
82transam's Avatar
Never Follow
why do you want to disable the buzzer? didn't you just spend like a year searching for one that would buzz? odd..........
Old Oct 5, 2002 | 08:41 PM
85RX7GS's Avatar
I did get mine to work, finally, but here's an easy way to disable it for all who hate it.
RyanFox
Sep 18, 2015 09:09 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
Amur_
Apr 26, 2002 09:25 PM
nad1967
Feb 3, 2002 05:20 AM
