Please help!!! Flooded and Weird sound from TB
Old Oct 4, 2002 | 10:19 AM
NA88FC's Avatar
Please help, is there any one had this problem before?
When I turn the key to "ON" position without starting the engine, there is some poping/pumping sound came out from the Thottle Body. Is there any problem?
My car is a 88 GXL
I removed the air pump and AVC. I put a metal plate to block the AVC hole. What else should I do? My car won't start now and flooded. I tried to unplug the spark-plug, there is so much fuel coming out. I let it dried and tried to re-start the engine again but couldn't. Is there any way to un-flood completely. Please help!!!
Thank you so much!!!
Old Oct 4, 2002 | 10:23 AM
blu_gxl's Avatar
well i don't know about the pumping sound but you can unflood by,
1. pull egi inj. (30A) fuse fromthe engine fuse block.
2. crank car for 10-15 sec.
3. put fuse back
4. start car
Old Oct 4, 2002 | 11:18 AM
GLHS's Avatar
Shelby Tuner & FC badass
make sure the door on the air meter isn't stuck open, this caused one car I was working on to keep flooding out.
Old Oct 4, 2002 | 11:27 AM
SureShot's Avatar
Seduced by the DARK SIDE
Is your air pump still running? With the ACV removed, it's open outlet will make a popping sound..
Old Oct 4, 2002 | 11:44 AM
NA88FC's Avatar
Thanks!!
My air pump is already removed, also, I removed those two things that control the 5th and 6th port. I blocked those holes.
I removed the AVC and blocked the hole too by a metal plate.
Old Oct 4, 2002 | 11:46 AM
NA88FC's Avatar
No, not the sound from the air pump. The sound is from the throttle body, there is a small cylinder with blue cap sits on/beside the throttle body. There is s "Denso" sign on that cylinder and 12V something with a plug. When I un-plug it, the sound is gone. I don't know what is going on with that cylinder???
Old Oct 5, 2002 | 05:50 AM
RETed's Avatar
BAC valve?
-Ted
LongDuck
Oct 7, 2015 08:12 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
Devon Murray
Sep 26, 2015 08:15 AM
