appropriate fuel pressure?
Old Oct 3, 2002 | 08:13 AM
foko's Avatar
I run an apexi rx6 single with 550/1300 injectors.
Was wondering what you guys think the fuel pressure should be at WOT?
After reading a couple dozen posts from a search, I'm not getting an answer.
TIA
Fabian
Old Oct 3, 2002 | 08:39 AM
jspecracer7's Avatar
1JZ powered
Re: appropriate fuel pressure?
TIA
Fabian
Not from personal experience, but from riding with Dragon, his rises from 3 kg/cm2 to 4 kg/cm2(appx. 29 psi to 43.5 psi)...at WOT.
Old Oct 3, 2002 | 09:14 AM
nocab72's Avatar
03 Cobra Killer
29psi sounds low. I can't monitor my fuel pressure at the present while @ WOT since the gauge is in the engine bay... But my base fuel pressure is set to ~40psi. With a 1:1 rrfpr, you should get 1 additional psi of fuel pressure with each psi of boost above the base (idle) fuel pressure, hence the 1:1 (rrfpr = Rising Rate Fuel Pressure Regulator).
K
Old Oct 3, 2002 | 09:31 AM
es's Avatar
es
Ideally what you want is about 75PSI MAX at the highest boost that you will ever run.
Some people run higher, but it taxes the pump.
And Nocab. No offense, but 1:1 isn't considered Rising Rate. That's a straight linear rate. Rising rate increases rail pressure exponentially compared to a linear rise in manifold pressure (boost). Therefore rising rate regulators can't be measured with a fixed ratio.
Old Oct 3, 2002 | 09:55 AM
nocab72's Avatar
03 Cobra Killer
Oops, thanks for the correction es. No offense taken, been hanging around my turbo honda friends too much...they all DO use rrfpr's
I figured you could call any FPR that raised full pressure in any ratio to boost pressure a rising rate FPR.
Old Oct 3, 2002 | 10:10 AM
es's Avatar
es
Yea, I figured you were just throwin' ricer slang...
J/K
Old Oct 3, 2002 | 10:50 AM
nocab72's Avatar
03 Cobra Killer
Look @ my car...I am a ricer. hahaha
http://flathat.woodstream.net/RX7/Im...2/P1010042.JPG
K
Old Oct 3, 2002 | 10:51 AM
es's Avatar
es
I was just joking nocab. You have a sweet car!
Old Oct 3, 2002 | 11:16 AM
nocab72's Avatar
03 Cobra Killer
I knew you were joking... hence the
I do like to roll up in my car, NOT pop the hood and let ppl think I'm a ricer... For some of the smarter ones the FMIC blows my cover... If it didn't have so many bent fins I could tell them it was fake.... hahaha
K
Old Oct 3, 2002 | 01:48 PM
mjw's Avatar
mjw
K
Your base fuel pressure is set w/o the vacuum line attached to the FPR, when you start the motor the vacuum at idle pulls the fuel pressure back down to a lower range. Next time your car is idling check out the fuel pressure, I bet it's not 40psi..
Matt
Old Oct 3, 2002 | 01:55 PM
nocab72's Avatar
03 Cobra Killer
I bet it is. w/the car running it's 40psi. With the key turned and the car NOT running it's ~50psi.
K
Old Oct 3, 2002 | 03:28 PM
rynberg's Avatar
Yep, I think the minimum Mazda spec is 36 psi for base rate.
Old Oct 3, 2002 | 03:30 PM
mjw's Avatar
mjw
Hmm.. well maybe that explains why my car isn't running right now!
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
