Rough idle. Vacuum leak at manifold likely?
Went over the vacuum diagram several times, inspected all the lines, and I still have a bouncy/low idle. Cranked the mixture screw up to compensate, that helped for about a week. It started about 2 months ago and after some hunting with a can of carb cleaner it seems to be around the intake manifold. I guess I will get some new o-rings and a gasket, in the meantime any other possibilities? I checked the hose that runs behind the carb.
gabescanlon
Sep 5, 2015 12:04 AM
