Sponsored by: CARiD
pro stock radiator
Old Sep 30, 2002 | 09:46 PM
london's Avatar
pro stock radiator
Any one ever tried this radiator on their rotary,its the griffin lightweight pro stock ,need some answers,Yes i need it to be streetable.
Old Sep 30, 2002 | 10:14 PM
peejay's Avatar
Old [Sch|F]ool
Probably nowhere near big enough... unless they've changed things, Pro-Stockers use the smallest radiators that will keep the engine from overheating as it idles in the pits, like VW Scirocco radiators or similar.
Old Oct 5, 2002 | 07:06 AM
RETed's Avatar
I concur - don't try running these on a street car, especially in hot ambient temps.&nbsp They do not have the cooling capacity for the engines.
-Ted
Old Oct 6, 2002 | 06:22 PM
london's Avatar
water
Actually the pro stock radiator holds more water than the stock radiator,Maybe itsthe fans too small.
Old Oct 6, 2002 | 06:51 PM
peejay's Avatar
Old [Sch|F]ool
Are you sure about that? The last time I was at Summit they had a couple in the scuffed/dented items room, and they looked barely larger than a heater core.
Old Oct 7, 2002 | 07:49 AM
london's Avatar
yes
Yes it holds more water ,i have one here that i am trying, maybe the fans are too small,after a highway run i have to add about 3 quarts of water,going back to a stock radiator. I also checked for leaks had none.
Old Oct 12, 2002 | 05:58 PM
Rx7carl's Avatar
Airflow is my life
london, which rad are you talking about?
GRI-2-28185-X
GRI-2-58185-X
And what about this one
SUM-380648
Do you have an empty weight on your radiator? And capacity?
Over on Mazspeed, boosted12a has this one
GRI-2-58185-X and says it works fine.
Old Oct 12, 2002 | 06:00 PM
Rx7carl's Avatar
Airflow is my life
The measuremeants indicate that it would fit perfectly with an under air/oil cooler in the stock location. I've been thinking about this for a while.
Old Oct 13, 2002 | 08:52 PM
london's Avatar
this one
This is the one i have sum-380648 and i took it out and went back to the stock 2nd gen and put a black magic on it and now its perfect ,guess that happens when you trying to get too fancy.
Old Oct 13, 2002 | 09:13 PM
Rx7carl's Avatar
Airflow is my life
Whyd you take it out?
Old Oct 14, 2002 | 06:45 AM
london's Avatar
took it out
I took it out cause after a highway run,i had to add about half a gallon of water , even used up all the water in the bottle,it was not leaking ,guess the surface area of it was too small even though it holds more water.
Old Oct 14, 2002 | 06:47 AM
Rx7carl's Avatar
Airflow is my life
So where did the water go? Your not making sense to me.
Old Oct 14, 2002 | 09:05 PM
london's Avatar
good question
well i have no idea .Maybe someone can tell me.
Old Oct 18, 2002 | 06:19 PM
Rx7carl's Avatar
Airflow is my life
Maybe there were air pockets in the motor. Did you refill it and drive it smoe more? If its not leaking, then I dont see how you have a problem.
streetlegal?
Mar 17, 2022 02:46 PM
