doing a N/A to TII swap
Old Sep 30, 2002 | 01:31 PM
rxspeed87's Avatar
well I know I said I was doing it a few times before and I also talked about just rebuilding my N/A
well I need a motor somewhat quick now that I think my coolant seals are going and it seems the cheapest way is to go with a J-spec.
right now my car is the 87 sport
I plan on using the N/A tranny till I get the money to replace it.... yes I know the N/A tranny is weak but I don't plan on getting on it till I get the TII tranny in there. though the N/A tranny in my car was on a motor that was running low 13's
I know I need the motor which should come with all the turbo intake and ****, also know I need the wiring harness and the ECU.
anything else you guys know of that I need or that I should replace while I am swapping motors.
what would the diff be between a series 4 and series 5 motor. I know compression is higher on the s5. and the s4 is supposed to be better for all out high boost apps but I don't plan on running anymore then maybe 15 psi in the future (not yet no money for new turbo) so would the 9:1 rotors be able to handle that fairly easy? also would there be anything else to worry about if I put a s5 motor in a s4 car?
is there a write up I can follow to help me out on hthis as well.
any help would be welcome as I can not wait much longer and I don't want to get rid of this car and end up buying some cheap 87 honda of some sort.
one last thing as far as motor mounts should I just go ahead and replace them with the polyurathane ones or just leave the stock ones in place ?
Old Sep 30, 2002 | 10:33 PM
rxspeed87's Avatar
come on guys
I am not just some N/A guy right now looking for info when I won't be putting it to use
my motor is going and I want to put a j-spec in there
need help as far as doing in
Old Sep 30, 2002 | 10:34 PM
BogusFile's Avatar
Search time
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
Nosferatu
Sep 5, 2015 02:13 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
TwentyDW
Sep 2, 2015 06:42 PM
