fc3s relieability???.....
Old Sep 29, 2002 | 09:07 PM
can anybody tell me how relieable the 87 rx-7 13b turbocharged ...........car is???? because there's this dealership thats sellling one for 2400 and I want TO BY IT SO BAD so i could kill dem dam si's........well anywayz....i was wondering if anybody with rx-7 experience tell me how relieable they are?? IS THE MAINTIANCE THE SAME AS A 4 cylinder car??/ is it easy to fix certain engine problems??? can anybody tell me any things i should look for or know about buying the car so that i am not getting a piece of junk???? any engine tips i should know about lyke anything normal or abnormal???? PLEASE JUST TELL ME HOW RELIABLE THEY ARE......THANKS EVAONE!!
Old Sep 29, 2002 | 09:28 PM
Turbo II FC's Avatar
Total Balance is Key
They are reliable but are high maintenance. As far as working on the car once you get down and learn simple things and do research I find it easier to work on a rotory then a piston engine. Everything is more simplified. When buying the car main things to look for are does it idle good, does it smoke on startup, also check out the wipers because its common for it to go out. When you physically drive the car make sure you get on it and go past 3800 because thats when the secondary injectors come on, its a common thing to have a slight hesitation. Good luck.
bl|nk's Avatar
Fok mi
a car's only as reliable as it's taken care of. If the car is properly maintained and always taken care of like it should be it'll last forever.. if the car is abused and neglected don't expect it to keep on ticking.
Old Sep 29, 2002 | 09:35 PM
Snrub's Avatar
To start off, what are you looking for that you didn't get in these identicle threads that you posted?
https://www.rx7club.com/forum/showth...hreadid=118990
http://www.teamfc3s.org/forum/showth...&threadid=4926
Perhaps something that hasn't been posted for you yet: The engine core itself is as reliable, if not more reliable than a typical piston engine. It pretty much works or it needs to be rebuilt.
RX-7 Buying Guide: http://www.aaroncake.net/RX-7/buy1.htm
Good General FC3S Problems, etc.: http://www.fc3s-pro.com
No offense, but the way your post is phrased would likely discourage a lot of people from replying. Posts that indicate you're looking for something along the lines of a civic don't go over well. The gramatical errors and slang tend to just add to people's impressions.
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
befarrer
Sep 22, 2015 09:33 AM
