fc3s relieability???.....
Old Sep 29, 2002 | 03:47 PM
can anybody tell me how relieable the 87 rx-7 13b turbocharged ...........car is???? because there's this dealership thats sellling one for 2400 and I want TO BY IT SO BAD so i could kill dem dam si's........well anywayz....i was wondering if anybody with rx-7 experience tell me how relieable they are?? IS THE MAINTIANCE THE SAME AS A 4 cylinder car??/ is it easy to fix certain engine problems??? CAN anybody tell me some helpful tips on the motor when i'm going to check the car out??? what bad or good signs i should look at when i'm checking out the motor??? PLEASE JUST TELL ME HOW RELIABLE THEY ARE......THANKS EVAONE!!
Old Sep 29, 2002 | 03:52 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
i think you should search for each of ur questions and you will find what you are looking for
-Jacob
Old Sep 29, 2002 | 03:56 PM
eViLRotor's Avatar
Brother of the Rotary
Reliability depends a lot on the previous owner(s) maintenance habits.
Personally, I would not call the 13bt a very reliable car, but when well maintained it will run a long time. Be wary of high mileage though, like 150k miles is a lot on the enigine and turbos.
Do a compression check. Just do a search for compression check on the forum, it will tell you what to do.
Warm up the car, take off the rad cap, and make sure that there are no bubbles in the coolant. That could mean the coolant seals are going.
Make sure the turbo spools and does not hesitate.
Make sure the engine does not smoke blue or white during hard acceleration, after the car has warmed up.
Easy to fix? fixing stuff on our car is not the problem. its diagnosing what's wrong, and getting parts for a good price (at least in canada...)
Old Sep 29, 2002 | 04:02 PM
silverrotor's Avatar
In general, when unmodified, the fc3s are VERY reliable. Although a high maintenace car, they have proved themselves to be highly reliable as opposed to our counterpart piston engines.
Having a Turbo sacrifices a tad bit less due to the Immense heat that It generates thus taking It's toll on the motor. The Turbocharged Rotary Engine doesn't last aslong as a Naturally Aspirated engine though.
Hey CrackHeadMel, are you all right? You look like you are going to pass out not to mention you look like your user name Implies.
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
befarrer
Sep 22, 2015 09:33 AM
