went non-seq and have a high idle?????
Old Sep 29, 2002 | 06:45 PM
fd3virgin's Avatar
just like the idel said. is that common. use to idle around 800-900 or a little lower. when i switched to non-seq it now idles around 1300-1400. kinda high. anyways will that be fixed when i drop my tuned pfc in
thanks for your help in advance. kevin
Old Sep 29, 2002 | 07:51 PM
OneBadRx7's Avatar
Lucky
Mine was weird at first too, it would idle high then when I put it in gear the idle would drop very low, I mean very low. After I drove it for awhile and let it warm up it was near perfect, better than it was before I went non-seq. The car has cooled down since and at first start up again it was a little high, nothing unreasonable but when warmed up no problem what so ever. Does yours come down when its warmed up or always stay that high??
Old Sep 29, 2002 | 09:09 PM
fd3virgin's Avatar
it's always high. maybe it will be different when i drop the pfc in this week and a midpipe. look forward to the flames. i figure i will be running rich b/c i have a cosmo pump going in also. did you port your wastegate???? thanks
Old Sep 29, 2002 | 10:06 PM
OneBadRx7's Avatar
Lucky
no I didnt, once I get my boost controller in and tune it I will see if thats necessary for my application. Hopefully it will be ok, hehe,
Steve
Old Sep 29, 2002 | 10:41 PM
ejmack1's Avatar
Lawn Ornament
you have a vaccuum leak.. jsut make sure you plugged everything you should have. I believe there is 20 plugs in all. And make sure your oil return line is connected
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
RotaryBobby
Sep 10, 2015 01:33 PM
The1Sun
Sep 7, 2015 10:21 PM
