does boost level affect spool-up
Old Sep 28, 2002 | 05:14 PM
Bluem's Avatar
Concept Motorsports
if u run higher boost will the turbo spool slower than runnin lower boost or the other way around ,or this doesn't affect spool-up???
Old Oct 1, 2002 | 02:30 AM
duboisr's Avatar
the top boost level is set by the wastgate, it is closed when the turbo starts to spool. the turbo does not know when the gate will open .It spools as exhaust is pushed through. the spool up to say 10 lbs is the same if boost is set at 12 or 20 lbs. The strain on the motor has alot to do with spool up time. more strain more exhaust pressure ,quicker spoolup
Old Oct 1, 2002 | 08:10 AM
Wade's Avatar
It won't spool slower but it will take longer to reach your target boost, which I think is what you are asking.
Bauer778
Nov 4, 2015 04:42 PM
Clacor
Sep 11, 2015 08:36 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
