weber help
Old Sep 28, 2002 | 03:17 PM
1rx7owner's Avatar
Lifes a garden dig it.
weber help
I have a 48dcoe and it seems like there is a dead spot. The car runs fine floored or just barely on the gas peddle but at a certain throttle it seems like it is either getting to much fuel or not enough. Makes the car spit and sputter and it just happens to be where the car cruises the best. I have the right fuel pressure fuel pump etc etc., Anybody have any advice?
Old Sep 28, 2002 | 03:27 PM
REVHED's Avatar
Hunting Skylines
First make sure the float level is to spec and the mixture screws are adjusted correctly. After that I'd maybe look at changing the idle jets.
Old Sep 28, 2002 | 03:38 PM
1rx7owner's Avatar
dont know how to check the float level. Ther mixture screws are adjusted to the best of my ability and when I put smaller idle jets in there it seemed to get worse. I already had the biggest idle jets that they make for it so I cant go any bigger I could just go smaller. This thing is driving me crazy.
Old Sep 28, 2002 | 07:12 PM
diabolical1's Avatar
wouldn't you need to change the size of the fuel or air jets, as opposed to the idle jets, if you're having cruising troubles? i'm not overly familiar with the DCOE's, but i think my Dells are based on their design ... so there should be three types of jets: idle, fuel and air ... right?
Old Sep 28, 2002 | 07:55 PM
mperformance's Avatar
first make sure there are no vaccum leaks. I found out with 45DCOE the same problem and it turned out to be bad gaskets everywhere I need to rebuild the carb completely. Start with a fresh set of gaskets then proceed to the jetting. Before the gaskets do the float level check.
Old Sep 29, 2002 | 06:48 AM
REVHED's Avatar
Hunting Skylines
Nope, the idle jets not only provide fuel for the idle circuit, (funnily enough ) but also for the transition circuit of the carb. When cruising the carb is running mainly on the transition circuit which is why the idle jets play a big part in controlling the mixtures.
Old Sep 29, 2002 | 06:52 AM
REVHED's Avatar
Hunting Skylines
I'd definately take a look at the float level. Having an incorrect setting will cause the carb to come on to the main circuit either too late or too soon which can cause the sort of problem you're having.
Old Sep 29, 2002 | 08:21 AM
1rx7owner's Avatar
Well how do I check the float level of it then. I have taken the float out and I see no way of adjusting it. I also dont know how to check the float level and see if it is correct. I didnt get and instruction book when I got the weber. Do you suggest I get one of those haynes weber manuals or does anybody know anybody that I can get one from.
Old Sep 29, 2002 | 04:01 PM
REVHED's Avatar
Hunting Skylines
Yeah, get a manual. I'd recommend getting the orginal Weber manual over the Haynes. I've had a look at both and the Haynes is shithouse in comparison.
Until then here's a scan of the float diagram.
Old Sep 29, 2002 | 04:02 PM
REVHED's Avatar
Hunting Skylines
... and the procedure.
Old Sep 29, 2002 | 04:04 PM
Felix Wankel's Avatar
Super Newbie
I like this page even if it doesn't cover rotaries.
http://www.teglerizer.com/dcoe/rasorcom.htm
Old Sep 29, 2002 | 05:11 PM
1rx7owner's Avatar
anybody know where I can get a weber manual then? Mine didnt come with one and I am really dissapointed now that it didnt. I will try to adjust it maybe next weekend. Thanks for the help I will try and see what happens.
Old Sep 29, 2002 | 05:15 PM
REVHED's Avatar
Hunting Skylines
I just realised the diagram I posted doesn't even provide the dimensions. Damn Haynes manual...
Old Sep 29, 2002 | 05:16 PM
Super Newbie
The old school floats must have been round. Mine are shaped like normal floats.
Old Sep 29, 2002 | 05:19 PM
1rx7owner's Avatar
mine are triangle shaped too but it looks about the same. thanks for the dimensions.
Old Sep 30, 2002 | 09:04 PM
bublhead33's Avatar
Go to one of the major book stores thats where I found mine and it helped me more then anything. Carbs are now a lost art. Good Luck
Coochas
44
Nov 5, 2019 11:08 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
NLPerformance
Oct 2, 2015 07:11 AM
