Help, still can't tell.
Old Sep 27, 2002 | 02:35 AM
SwooshMand's Avatar
Alright i was pretty sure my 88 n/a was a gxl. It has power everything, aas, but as for the lsd and the rear brakes i'm still a little unsure. From my understanding the rear brakes were supposed to look basically the same as the front, and also on my rear diff. i was unable to see any kind of labeling. Again from my understanding it should say that its a lsd if it in fact is. Take a look at the pics and maybe someone could tell for sure. Thanks.
Old Sep 27, 2002 | 02:49 AM
SwooshMand's Avatar
here's the rear brakes
Old Sep 27, 2002 | 02:53 AM
SwooshMand's Avatar
Here's the rear diff.
Old Sep 27, 2002 | 02:54 AM
SonicRaT's Avatar
Super Raterhater
if its got AAS, it's a GXL
Old Sep 27, 2002 | 04:16 AM
Rs4Racer's Avatar
whats aas?
never mind... auto adjusting suspension?
so if my car has it its a gxl?
my car is a 89 na .... or so im told
Old Sep 27, 2002 | 05:43 AM
LiL'7's Avatar
Did the 10th anniversary's have aas or were they different.
Old Sep 27, 2002 | 08:13 AM
Ryde _Or_Die's Avatar
I thought some TIIs had AAS as well? Or are you just saying that the GXL is the only NA with AAS?
Old Sep 27, 2002 | 08:44 AM
Turbonut's Avatar
TII/10 AE didn't have Adj. Suspension as far as I know..
Old Sep 27, 2002 | 09:26 AM
DaleClark's Avatar
RX-7 Bad Ass
Only GXL's had the auto-adjusting suspension - that was it. Nothing else. In Japan, all top-model cars had AAS, though. And, no, the 10th Anny didn't have AAS either .
The rear brakes are correct - those are the "big" rear brakes. All rear brakes basically look the same, but the "big" brakes are vented rotors in the rear instead of solid rear rotors.
Dale
Old Sep 27, 2002 | 09:32 AM
Turbonut's Avatar
One other item-To check for LSD-Jack up rear and turn wheel, if both turn the same direction simutaniously-LSD. If only 1 turns, or the opposite wheel turns the opposite direction-Open rear.
Give it a try.
R7rexy
19
Sep 2, 2015 10:24 AM
kettlman
13
Oct 6, 2003 09:43 PM
ULTIMATERX7
Sep 16, 2003 08:01 AM
T2R7
Dec 26, 2002 12:40 PM
