Turbo Question
Old Sep 26, 2002 | 06:40 PM
xstacy7's Avatar
I love when things work
Cool Turbo Question
Do you have to remove the engine to take the turbo's off or can it be done with the engine in? Thanks
Old Sep 26, 2002 | 08:31 PM
P'cola FD's Avatar
Hamado things my way!
You don't have to remove the engine. Take off all the intake pipes, the y-pipe, the downpipe, and all related heatsheilds, and the turbos will come out. Not a big deal, but if you haven't done much mechanical work before, then you should do a lot of researching first. Or take it to a pro.
Old Sep 26, 2002 | 08:41 PM
Street King's Avatar
*** Bless Texas!
The only way to learn is to read up and take a stab at it. If anything messes up you can take it to a pro to fix. =)
Old Sep 28, 2002 | 01:39 AM
xstacy7's Avatar
thanks, is there anything fatal i should know about doing this? (Drain the oil, etc.)
Old Sep 28, 2002 | 01:48 AM
RotorMotorRX7's Avatar
No you should be fine.. turbo is exhaust driven.. just make sure the car is off obviously. and cool
Old Sep 29, 2002 | 11:24 AM
xstacy7's Avatar
Unhappy
Thanks for the help
Old Sep 29, 2002 | 11:59 AM
*** Bless Texas!
Doesn't the turbos have oil lines going to them?
Old Sep 29, 2002 | 02:28 PM
Hyperite's Avatar
Vagina Junction
Yeah, there are oil and coolant lines going to the turbos, but truthfully, not much leaks out when you pull the turbos off. If it's about time, you might as well drain both before working on it anyway.
Other than that, it's not tough to get 'em off, but make sure you soak those bolts with wd-40 or other liquid wrenching stuff or you'll be doin a lot of cursing.
~Tom
Old Oct 1, 2002 | 08:56 PM
xstacy7's Avatar
thanks, that's good to know when i'm yankin' off those suckers
Old Oct 2, 2002 | 12:26 AM
redrotorR1's Avatar
LS6 Convert
~Tom
Wish someone would've told me that a few months ago ...
I think my neighbors are scared of me now.
Old Oct 3, 2002 | 09:22 PM
xstacy7's Avatar
how long of a process do you thing this will be?
Old Oct 3, 2002 | 10:10 PM
P'cola FD's Avatar
The first time I pulled the turbos, it took around 8 hours to get them off. After doing it more times then I'd like, I can get them off in about 3-3.5 hours, and put them back on even quicker. Plan on it taking longer rather than shorter, so if anything comes up you won't be in any trouble.
hotshot2014
Jul 18, 2017 02:30 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
