car will idels extremly rough
Old Sep 25, 2002 | 11:14 PM
redrx's Avatar
i figured it was a vacume line, looking at them I cant see any that are leaking or disconected, does anyone know the specific hose I should look for?- could it be something else?- spark plugs are newer- so are the coils and wires- also there seems to be no loss when accelerating
Old Sep 25, 2002 | 11:48 PM
Pedestrian X's Avatar
SpAz!
seomtimes if u listen carefully you can hear a vacuum leak hissing... so start her up and stick your head up under the hood and see what ya hear.
Old Sep 25, 2002 | 11:50 PM
Redwood's Avatar
Find Racing
What year and engine?
There isn't a specific hose. The best you can do is listen for a leak, then see if it fluctuates with rpm increase. This helps to isolate it.
While you have your head under there and it's running, rev it up a little (place your index finger on the throttle and push ) and see if you notice anything odd, especially hissing.
Old Sep 25, 2002 | 11:53 PM
When hunting down vacuum leaks, get a can of carb cleaner.. the cheap stuff if possible. And just spray down your lines. If your rpms jump, you have a leak. Then the fun part comes from hunting it down....
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
sYnth.
Aug 14, 2015 01:37 PM
bb6guy
Aug 12, 2015 03:29 PM
