How do i remove the pressure plate from the tranny?
Old Sep 24, 2002 | 09:22 PM
V8KILLR's Avatar
Question How do i remove the pressure plate from the tranny?
I heard there is a clip or fork to remove to get the pressure plate off the tranny. Is there some detailed instructions or some pictures that would help?
Thanks!!
Old Sep 24, 2002 | 09:30 PM
BLKTOPTRVL's Avatar
That question doesn't really make any sense. The pressure plate is around the shaft (input) between the transmission and the engine. To remove the plate, you must remove the engine or transmission first.
Old Sep 24, 2002 | 09:40 PM
V8KILLR's Avatar
Oh boy.... ok, the tranny is removed from the engine and the pressure plate is still on the tranny shaft.
Old Sep 24, 2002 | 09:46 PM
poss's Avatar
Slower Traffic Keep Right
i assume you want to disconect the input shaft to the transmission from the clutch assembly. you need to pull the clutch release fork away from the pressure plate, then insert a large screwdriver to pry the throw-out bearing away from the pressure plate. mine popped right off without much effort once i found the right areas to pry against. sorry if my explaination didn't make much sense, but check the shop manual. it helped me out.
Old Sep 24, 2002 | 10:41 PM
yodaddy's Avatar
push to pressure plate back and pull the throughout bearing towards you. there should be a little ring around the throughout bearing. romove that ring and voila!
Old Sep 24, 2002 | 11:10 PM
2GSLSE's Avatar
If you are trying to release the clutch so you can remove the engine or trans look in the inspection hole at the bottom of the trans you will see a thin ring use two screwdrivers and wiggle it towards the engine.
Old Sep 25, 2002 | 09:37 PM
V8KILLR's Avatar
Thanks guys... that what i was thinking... but it has been to the paint shop for awhile to get the engine bay painted and the tranny is in there.... SO i will look at it in more detail when i get it back.
Thanks!
Snoopy FD
Dec 8, 2015 01:45 PM
