How Do I Get The Flywheel to Connect to the Pressure Plate?
Old Sep 23, 2002 | 02:05 PM
vudoodoodoo's Avatar
I'm putting my engine in right now. I can't get the fywheel to move closer to the pressure plate. The pins on the flywheel need to go into the holes on the pressure plate. I can't get it it to move anymore.
The engine is all the way in. It lines up w/ the bell housing and everything...
Old Sep 23, 2002 | 02:37 PM
ejmack1's Avatar
Lawn Ornament
not sure what you mean.... the flywheel is bolted onto the ecentric shaft... the Clutch disk is put on with longer shaft side sticking towards the engine side, the pressure plate then bolts onto the flywheel with 6 bolts, the dowels fit in between the bolts on three sides.....
Old Sep 23, 2002 | 02:46 PM
twstd rx's Avatar
I think what ejmack1 is trying to tell you is that the clutch assembly should be bolted onto the flywheel BEFORE you install the engine.
Old Sep 23, 2002 | 04:44 PM
ejmack1's Avatar
Lawn Ornament
oh now i get it, you are tryin to bolt on the pressure plate after getting the tranny up and in there.... It is possible, alot more difficult but possible. Just make sure you have the alignment tool and try to get those dowels aligned..
Old Sep 23, 2002 | 05:01 PM
When we removed the engine, only the flywheel came out w/ it. Now we are trying to put in the new engine w/ the flywheel. We got the engine in and aligned it w/ the bell housing. We also align the dowel pins w/ the holes on the pressure plate. the thing is the pin and the holes are still far out from each other. We can't get them to move any closer to each other to make the pin go into the hole. Do I just use a screwdriver and try to pry em together?
Old Sep 24, 2002 | 06:21 AM
We decided to take the clutch off the car and stick it on the engine and put the engine back in the car.
Now there is no pressure on the clutch pedal. I can just push it down w/ no resistance. Some fluid is dripping out of the bell housing access hole. Is this clutch fluid? Why is my clutch pedal going down so easily and not going back up by itself? Do I have to bleed the clutch?
Old Sep 24, 2002 | 07:17 AM
Brede's Avatar
I had no problems assembeling my pressureplate and flywheel after installing the engine.
There will be a gap between the pressureplate and the flywheel, just install all the bolts (6?) and force the components together tightening the bolts!
Just make sure the dowels line up! And tighten the bolts evenly!
Great way to do it if you don't have the alignment tools (as the clutchdisk is allready on the shaft and centered).
Old Sep 24, 2002 | 07:33 AM
Rated R1's Avatar
Oji San
You need to pull the access panel and see what is going on. You may have shot the piston out of the slave cylinder.
Old Sep 24, 2002 | 07:40 AM
rotorbrain's Avatar
fart on a friends head!!!
i bet thats what that snap was when you were pushing the clutch pedal while you were pulling the engine.
paul
Old Sep 24, 2002 | 07:55 AM
Rated R1's Avatar
Oji San
It happened to me. Long story but I forgot to snap the TO bearing into the collar. If you are leaking fluid inside the bell housing it is not a good sign.
Old Sep 24, 2002 | 08:04 AM
Dammit! Do I gotta pull the engine out again?
Old Sep 24, 2002 | 03:19 PM
Originally posted by Dont_Be_A_Rikki
I hate when that happeneds.
-Rikki
Can I fix it through the hole in the bell housing? Or do I gotta pull the engine out again?
God dammit!
Old Sep 24, 2002 | 03:34 PM
ejmack1's Avatar
Lawn Ornament
You gotta pull the tranny out... why pull the engine when you already have it in there? The shaft came out of the slave cylinder, that is why you are leaking fluid, the reas on for that is you never pressed the throw out bearing into the pressure plate... when you pressed on the clutch the slave cylinder had nothing to push against so it just kept going.... you might as well go to autozone and pick up a rebuild kit for the slave cylinder.. 9 bucks wont hurt anything...
Old Sep 24, 2002 | 04:00 PM
neevosh's Avatar
The Dude Abides
It sounds like the rod from the clutch release cylinder fell out. That happened to me when I put my engine back in. Open the service holes up and take a look inside from the top of the engine to see the clutch fork. If that's your problem, take the clutch release cylinder off, and search around for the rod. Assemble it all and put it back on. Then bleed the clutch and you should be all set to go.
Old Sep 24, 2002 | 04:23 PM
Ok. Thanks for the info guys!
Old Sep 24, 2002 | 04:48 PM
ejmack1's Avatar
Lawn Ornament
oh ****, sorry for the mis information, i was at work.. lol, all you have to do is unbolt the slave from the tranny and do the rebuild on it that way... doh....
Old Sep 24, 2002 | 05:43 PM
Cool, we're gonna drop the tranny tomorrow.
Old Sep 24, 2002 | 06:26 PM
Rated R1's Avatar
Oji San
You do not have to drop the transmission. Just unbolt the slave from the bellhousing. You MIGHT also need to remove the starter. It has been over a year since I have done any work on the tranny.
Old Sep 24, 2002 | 06:39 PM
rotorbrain's Avatar
yeah, you have to remove the starter. . . unless you have superduper stretchomatic hands from mattel. haha.
paul
Old Sep 24, 2002 | 09:51 PM
BLKTOPTRVL's Avatar
Now that there is fluid inside the bell, isnt there a chace that the new clutch has been contaminated and will need to be replaced (or at least thouroughly cleaned)?
Old Sep 24, 2002 | 10:04 PM
OK thanks!
I hope I don't have to take it out and clean it...
13
Jan 9, 2018 11:19 AM
yetter227
20
Sep 5, 2015 11:57 PM
