need help locating used brake rotor for 84
Old Aug 17, 2001 | 02:58 AM
HOZZMANRX7's Avatar
Driving RX7's since 1979
GS, GSL is same rotor but different from GSL-SE. Which is it?
Also, what part of the world you at?
Old Aug 18, 2001 | 02:37 PM
RedRacinTII's Avatar
Depending on where you are, you should be able to go to just about any junkyard and pick one up cheap.
Old Aug 21, 2001 | 09:07 PM
HOZZMANRX7's Avatar
If you get one from a wrecking yard, be sure and measure its thickness with a micrometer. If you don't own one, buy one. Good investment. Thicker is better. And get it turned at a local machine shop before installing.
Remind, SE rotors are different in size and bolt pattern than all other 1st Gens. Check you shop manual or call local brake shop and find out how think they are new and how thin before they are discard. Discard thickness should be stamped on your current rotors.
To make it easy, maybe other rotor heads can recite discard thickness's for the various years and models for yah.
Old Aug 22, 2001 | 07:39 AM
two owner's Avatar
Newbie
Discard thickness on my '85 GS is 17 mm, and I can currently slip a 16 mm wrench over the edge of the rotor. Needless to say, I just ordered two new ones from Mazdatrix, $59 each.
Bill
Old Jun 25, 2006 | 03:59 PM
frankyv's Avatar
do you still need rotor?
ive got two front rotors that fit franky
Old Jun 25, 2006 | 06:21 PM
Rogue_Wulff's Avatar
Too old to act my age
Damn, talk about reviving the dead....... A 5 year old dead post!!!!!
Old Jun 25, 2006 | 06:25 PM
rotor vs. piston's Avatar
Function > Form
LOL!!! at least we can never acuse him of not using the search button.
Old Jun 25, 2006 | 07:56 PM
trochoid's Avatar
Old Fart Young at Heart
It can only get better, he joined today and is already trying to sell parts and found the 'Purple Menace'
Marty RE
Aug 13, 2015 11:19 AM
