buying a T2. what do i need to do to drive it home
Old Sep 23, 2002 | 10:10 AM
Moxeys93RX7's Avatar
p;im going down to jersey this weekend to pick up a T2 (10ae). the car has been sitting for a few years but started up every few weeks. i know it had a bad hot start problem (leaky injectors) which is why it hasn't been driven for the past few years. what do i need to do to be able to drive it home (about 2.5 hours away). im going to change the oil and coolant and swap out the injectors. anyhitng else i should do or check while im at it? im going to go through it when i get it home i just need to make sure it will get me there
Old Sep 23, 2002 | 10:11 AM
Pinfield357's Avatar
all i can say is your gambeling with this one
Old Sep 23, 2002 | 11:40 AM
autocrash's Avatar
Now with more 1st Gen!
hmm... uhmm... keep your foot down the whole way!
(what foot, you ask: why the important one! )
Old Sep 23, 2002 | 11:48 AM
i will have a few hours to go over the car. and if it came down to it i could get a dolly for it. do u think i should atf it. do everyhting else then fire it up before i drive it home?
Old Sep 23, 2002 | 12:02 PM
Roy James's Avatar
My cars louder than yours
I dont think i would try it. I would just go ahead and get the dolly and get it home before i started tinkering with it. I would check the compression though, and all the vitals. Who knows, it maybe very well be good to drive home with, but better safe than calling AAA or a wrecker to tow you home if it breaks down.
Old Sep 23, 2002 | 12:07 PM
well im going down in my friends blazer. i would rather try and drive it home but if somehtign does happen i can pick up a dolly. i don't reall want to unless i have to
Old Sep 23, 2002 | 12:08 PM
Roy James's Avatar
Well, go for it, and good luck.
Old Sep 23, 2002 | 12:09 PM
Ryde _Or_Die's Avatar
How about putting some MMO in the fuel and oil.
Old Sep 23, 2002 | 12:21 PM
autocrash's Avatar
How bout you rent a dolly for the blazer, but plan on driving it back.. that way your friend can follow you in the blazer and if something does happen you can just tow it home?
More expensive than just driving it home, but cheaper than paying a tow truck to pull it!
Old Sep 23, 2002 | 12:40 PM
the prob is he just got the blazer and isn't too sure about it making it either. he also doens't have a hitch for it. im looking around to find out about renting one but not sure if it will work out. anyone around brick nj want to make a few $ towing it to ct for me?
Old Sep 23, 2002 | 01:50 PM
rgordon1979's Avatar
LS what?
This post just gets better and better! I think ryder and uhaul runs weekend specials that are pretty cheap. If they are not running a special, just keep shopping back and forth, they will lower the price to get your business. They did for me anyway. I would try that out rather than trying to drive home with two cars you are unsure about.
Old Sep 23, 2002 | 02:57 PM
TURB0 II's Avatar
Panda Style
yeah thats risky. u never know what might happen. and a 10AE is a special car.
Old Sep 23, 2002 | 03:16 PM
They rent pickup trucks at u-haul. I think they're like $20 a day or something fairly cheap(might wanna look into cost for mileage though). Rent a truck and a dolly.
Old Sep 23, 2002 | 04:12 PM
i'll call around tommorow and see what i can find out
cristoDathird
28
May 30, 2019 08:47 PM
Th0m4s
Feb 26, 2019 02:04 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
LMBTG
Aug 15, 2015 01:43 PM
