smart enough to figure this out????
Old Sep 22, 2002 | 03:32 PM
94 rx7 a/t idles good, but will not accelerate past 15 mph. Compression test done by a dealer averaged 4-5 per cyl. I know this is low compression, but shouldn't the car still go more than 15 mph? Tried my friends power apexi fc and we got it past 2000 rpms for the first time. He said he adjusted the fuel down to dump less fuel in and it revved up better. He doesn't know much about the power fc and said he thinks the engine is shot. But the car does not smoke or idle bad. So w
hat do you fellow rotor heads think??
Thanks Rob.
p.s. Another mechanic said the compression sounds good to him and that some times madza dealers make mistakes about compression test. He feels like it is probably a bad ecu, but a/t ecus are hard to come by.
Old Sep 22, 2002 | 04:20 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
4-5?
Old Sep 22, 2002 | 05:04 PM
Orange!FD's Avatar
Re: smart enough to figure this out????
Originally posted by rx7r3
...averaged 4-5 per cyl.
I think I see your problem.
Seriously, though, I think it's hard to screw up a compression test THAT badly, unless you forget to crank the engine. Have you checked vacuum at idle?
Old Sep 22, 2002 | 05:16 PM
jr426's Avatar
Might be a pluged cat.
Old Sep 22, 2002 | 06:43 PM
GsrSol's Avatar
Z06 powered FD
Could be many things. Turbos not spinning, sensor on tranny, bad ecu, really clogged cat.
Old Sep 22, 2002 | 07:01 PM
artguy's Avatar
WTB** Very Low Miles 94-95
the sensor...up on the drivers side firewall in the engine bay...a direct line in front of the steering wheel...by the ignition sort of...has a little vacuum hose coming off it...if that is bad you wont get past 25 mph in my experience....check to see if it is plugged in.
j
Old Sep 22, 2002 | 09:17 PM
duboisr's Avatar
that is the MAP sensor on the fire wall,do check it as artguy says
Old Sep 22, 2002 | 10:42 PM
c00lduke's Avatar
also make sure the fuel presure regulator is plugged in, the little hat looking think between the LIM and firewall
Old Sep 22, 2002 | 10:52 PM
jf4828's Avatar
will an fd run on 4-5? I had a hard time @ 6.....
Old Sep 23, 2002 | 10:14 AM
Could it be the oil metering pump? Annother mechanic just picked up this error code?
Rob
Old Sep 23, 2002 | 01:24 PM
BUMP^
Old Sep 23, 2002 | 02:03 PM
BUMP^
Old Sep 23, 2002 | 02:05 PM
GsrSol's Avatar
Z06 powered FD
Yes! If the oil metering pump goes out, it throws the check engine light and puts you in "limp" mode, from what I understand.
That's your problem!
Old Sep 23, 2002 | 02:08 PM
GsrSol's Avatar
Z06 powered FD
I think there's one on eBay right now if you can't find one locally.
Oh, you never said the CEL was on.
Old Sep 23, 2002 | 02:18 PM
Sorry, but it didn't show up until we cleared the computer! Hey could you tell me how to look it up on e-bay? Thanks, Rob.
Old Sep 23, 2002 | 02:38 PM
JUSTgotMINE's Avatar
the one on ebay is for the 2nd gen ....I looked it up for ya. Try mazdarecycling..call them not email.
http://www.mazdarecycling.com/
Old Sep 23, 2002 | 02:54 PM
Thanks, they have one in stock! I'll order it asap! Thanks, Rob.
Old Sep 23, 2002 | 03:27 PM
mblachford's Avatar
Let us know how the install goes Rob. Good luck with her
Old Sep 24, 2002 | 12:06 AM
GsrSol's Avatar
Z06 powered FD
From what I understood, if the omp goes out it puts you in the limp mode as a safety feature so you won't mess up the motor and your car acts just like it's in limp mode.
BTW this is the one I saw on eBay, already ended though.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1859400648
Good luck.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
eplusz
15
Oct 7, 2015 04:04 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
