Passenger Airbag On/off switch?
Below- "Esses" at RA
How coiuld I do this.........would love to take my kids for rides but my wife won't allow without the airbag disconnected?
Anyone done it and is it easy?
TIA.
David
TIA.
David
Open up! Search Warrant!
I removed the airbag from my wifes car when I took the steering column out. It wasn't an RX-7 but most airbags work on the same principle. Her car has three sensor in different positions in the front of the car. To compress 2 of the 3 sensors, you have to hit a solid object at or above X mph. This completes a circuit sending power to the air bag. This power ignites a dry chemical and the flash explosion produces gases that inflate the bag. When you remove the airbag, the bag and canister containing the chemical is one unit, with a wire harness attached. If I remember correctly, it only has 2 wires. Proceed at your own risk! What I would do is cut one wire, run it to a toggle switch, and there you have it. If you want to permenantly disable it, remove the wire harness.
dont put a toggle switch in the wires. the airbags are like small bombs, if your switch shorts out boom.
it would be much better to leave them alone, or take the whole system out.
mike
mike
