tire sizes for 1st gen
Old Sep 20, 2002 | 09:43 PM
jayroc's Avatar
What's the biggest size tire that will fit on a 1st gen? I ran across one in a yard that had 205/60R13s on it. I'd like to get some thing a bit wider.
Old Sep 20, 2002 | 10:27 PM
357's Avatar
357
Stratoflattener
The general concensus is that 205's are the widest tire that will fit on a stock car without rubbing. Another thing is that you're gonna have a real hard time finding 13" meats that are wider than that. I'm currently in the market for new tires, and I'm trying to decide between 185/60R13 Yokohama AVS Intermediates, and 195/60R13 Sumitomo HTR-200's, if that helps
Old Sep 21, 2002 | 12:23 AM
S2-13BT's Avatar
I currently use 205/60R13s and get some slight rubbing at extreme lock. They're Yoko A509s
Old Sep 21, 2002 | 12:28 AM
gamble302's Avatar
roadkill hats rock
ive got 205/60r13 sumitomo htr-200's with no rubbin on st springs and tokico blues. i wish they had some 205/60r13 yoko avs es100's mmmmmm that would rock
im gonna go 15's when i get new rims just so i can get better tire choices unless you know anyplace that has some decent 13's online?
Old Sep 21, 2002 | 05:53 AM
FD Racer's Avatar
sold the FD...kept the FB
I run a 205/50/15 all the way around with no rubbing on stock suspension.
Old Sep 21, 2002 | 10:15 AM
357's Avatar
357
Stratoflattener
Gamble: Currently, the Tire Rack has Yokohama AVS Intermediate (UHP) 185/60R13's on sale for 38 a tire. I'll be getting a set of those within a couple weeks.
Old Sep 21, 2002 | 12:48 PM
mar3's Avatar
Administrator
I'm running 205/50/15s up front and 225/50/15s out back. When this combo was on the '80, I had to roll the fender-lips in the back,not at the front and that was even with cut springs up front. When I put the same rims and tires on to my current '84, I had to roll all the lips but it's now cured of rubbing...
Old Sep 21, 2002 | 02:01 PM
inittab's Avatar
I read your email
I'm running Sumitomo HTR-200's in 205/60/13. These tires stick well BUT if I was to do it again I would try to get 195/60/13's instead. The stock rims are a bit narrow and when mounted up with 205's the tires have too much side wall flex for my taste. My next set of tires will be on 15" rims.
Old Sep 21, 2002 | 06:43 PM
gamble302's Avatar
roadkill hats rock
yeah i saw that, but thats not big enough for my streetports tire need
Old Sep 25, 2002 | 10:07 PM
i just got sumitumo htr 200 215/50/13 feel real nice hang corners and a bitch to park
Old Sep 25, 2002 | 11:20 PM
Sammymatik's Avatar
noticed that no one is running 14s? I know that on mine at the moment i got 195/65/14, not a bad size but my new set will be 205s for sure, in the 14inch range I do have a lot of choices. Haven't checked for 13s though.
Old Sep 26, 2002 | 12:01 AM
gamble302's Avatar
roadkill hats rock
when i get new wheels im going 14s or 15's just for better tire choices. you can get the new yoko es100's for 80 a pop i think at tirerack in 205/50r14's and from what i hear they are awesome tires.
add wheels and tires to my list doh.
gamble
Old Sep 26, 2002 | 12:11 AM
Suparslinc's Avatar
It's Back!
I can vouch for the AVS. Had those on my series V in 205/60/15 and they were sticky as glue, plus good in the rain despite what tirerack may say.
Old Sep 26, 2002 | 12:15 AM
gamble302's Avatar
roadkill hats rock
runs out and buys new wheels and tires.....
Old Sep 26, 2002 | 01:58 AM
Manntis's Avatar
add to cart
can we make one of these weeekly tire size questions a sticky?
Old Sep 26, 2002 | 02:13 AM
Suparslinc's Avatar
It's Back!
noticed that too since I've been back...
But I'm interested in the topic since only a very limited selection is available in 205/60/13 which is my size.
Old Sep 26, 2002 | 06:59 AM
treceb's Avatar
same here, except my suspension might be a little bent. cause i get a very light rubbing on the drivers side front. nothing a couple of washers couldnt take care of.
Old Sep 26, 2002 | 04:26 PM
357's Avatar
357
Stratoflattener
Hmmm, I'm definitely going to get some of those AVS's then, if only I had the money now !
Old Sep 26, 2002 | 05:56 PM
FD Racer's Avatar
I need new tires bad. After checking TireRack's website,
I'm stuck between these two..... any comments?
Old Sep 26, 2002 | 06:50 PM
gamble302's Avatar
roadkill hats rock
id say yokos are a better buy for the money. a set of bridgestones arent $120 better than a set of the es100's
gamble
Old Sep 26, 2002 | 08:18 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
I've had the AVS ES100's on my car for 2 days so far and love them. 16's have a much stiffer sidewall than the 14s, but these stick much beter and don't squeal much at all...
[img]http://www.digitex.net/ecarter/pics/wheel7.jpg
[/img]
Old Sep 27, 2002 | 03:34 AM
680RWHP12A's Avatar
I have abunch of first gens, the biggest tire / wheel combo i have gotten to fit without rubbing is 17"x 8" all around with 215/40/17.... i have a pic on my website under our cars, the red one...@www.rotaryshack.com ..... my street class car has 15x9 rear with a tire size of 275x50/15 .... those stick out 3" and would rub but i limit the suspension travel....I also had to get those wheels drilled to fit the early type bolt pattern....My latest wheel projects include upgrading my red car with 19" wheels , but i need to but coilovers for the front to clear the wheel/tire at the top.... and i got a set of the convertable BBS mesh, i'm trying to get those redrilled,,,,,lots of money but i love my mazdas!!!!!!!!!!!!
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
