Turbo Question
Old Sep 20, 2002 | 06:13 PM
RXSETH's Avatar
Turbo Question
Does anyone know if the Chevy or Ford turbo diesel trucks have T04E's or just T04 turbos on them. I was just wondering to see if I could find one at a junkyard cheap. Thanks
Old Sep 21, 2002 | 01:25 AM
RETed's Avatar
1) These things don't fit on the stock turbo manifolds.
2) A T04 turbo requires (at least) and HKS 13B turbo manifold that's going to cost close to $300.
3) Getting the fuel support and pipe and hose adapters to actually run a T04 turbo adds at least a couple GRAND more to this cost.
If you're thinking of trying to get cheap on this upgrade, it's going to bite you in the *** or cause your car to end up being a very big paperweight in the garage.
A proper T04 turbo upgrade is going to cost you at least $5,000.&nbsp A front mount intercooler has a lot to do with the added cost and is REQUIRED.&nbsp The fuel system is also the other big cost - the stock fuel injectors don't have enough capacity to support that kinda power (the stock fuel injectors 4x550 can barely handle 300hp at the "crank").
-Ted
Old Sep 21, 2002 | 03:25 PM
RXSETH's Avatar
I'm not an idiot Ted, I know I need all that. I know I need bigger injectors and a front mount. I also know I need to order a manifold from HKS and I need an external wastegate for it as well. All I wanted to know was if the bolt pattern was the same as the T04 manifold bolt pattern. Sorry about the little rant, but I don't like being told things I already know and being treated like a dumbass. Thanks anyway.
Old Sep 23, 2002 | 09:19 PM
RETed's Avatar
#1 answered your question then.
-Ted
Old Sep 23, 2002 | 09:22 PM
Felix Wankel's Avatar
Super Newbie
The one on my brothers old 97 Powerstroke appears have an internal wastegate on it, and the A/R on the turbine housing is huge (like 1.32 or something like that).
I haven't checked his new 2002 one yet though.
Old Sep 25, 2002 | 04:11 PM
RXSETH's Avatar
All I wanted to know was that if the flange off the turbo was a T04 style so I can find one of those turbos,THEN go get a manifold.
Old Sep 25, 2002 | 06:54 PM
Super Newbie
What for? The specs are all wrong.
Old Sep 25, 2002 | 06:59 PM
RETed's Avatar
He's replying to me you dumbass...
-Ted
Super Newbie
You're the dumbass, dumbass
I think.
Old Sep 25, 2002 | 07:24 PM
TBoost's Avatar
Originally posted by RETed
[B]1) These things don't fit on the stock turbo manifolds.
That not entirely true. You can get away with a stock turbine housing and mate a T04E compressor housing to the car. This works!
Again, not necessarily true for the reason above.
A proper T04 turbo upgrade is going to cost you at least $5,000. A front mount intercooler has a lot to do with the added cost and is REQUIRED.
Nope. I'm running a T04E Turbo 57 trim with stock intercooler @ 14psi of boost. All is well.
True.
Ted, are you not studying anymore...
-M
hotshot2014
Jul 18, 2017 02:30 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
