Interior Lights wont go off
Old Sep 20, 2002 | 04:10 PM
Hi, I have a 1987 TII.
when i got it, the door switch was broken and the interior lights wouldnt go off, so i just took out the fuse until i could get a switch.
Now I have a new switch in there and the lights still wont go off? Any idea what it could be?
Thanks
Old Sep 20, 2002 | 04:15 PM
KNONFS's Avatar
B O R I C U A
Re: Interior Lights wont go off
Thanks
The cable is grounded at some point, if the door switch was broken, I'll try there first. Make sure that the cable is not touching the metal surroundings (grounded) when the switch is installed.
Disconnect the cable from the switch and see if the lights go off.........
Old Sep 20, 2002 | 10:51 PM
Silkworm's Avatar
Has been.. hangin' around
I know this probably sounds stupid, but are you sure the headlight switch isn't turned all the way to full bright? Going one click past that turns on the interior light, IIRC.
PaulC
Old Sep 21, 2002 | 12:44 AM
Icemark's Avatar
PaulC
This is a Mazda, not some silly GM product. The dash dimmer/headlight switch does not control the interior lights on a Mazda built product.
Old Sep 21, 2002 | 01:01 AM
Silkworm's Avatar
It doesn't???
Sorry, it's been years since I had an interior light to turn on
PaulC
Old Sep 21, 2002 | 11:46 AM
That didnt work either......anyone else have any ideas? This is driving me nuts.
Thanks
Old Sep 21, 2002 | 11:54 AM
Aaron Cake's Avatar
Engine, Not Motor
The wire to the switch has shorted and is grounding somwhere. You will have to trace along the wire to find the problem.
Jutta_J
Mar 25, 2017 11:24 PM
82streetracer
Aug 23, 2015 09:28 AM
