What to look for when buying used rotors?
Old Sep 19, 2002 | 09:25 PM
BrainFood's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1859288023
I was thinking about buying these because I want to turbocharge the n/a I will be putting into my 510, I wont be doing the the rebuild until sometime next year but this looks like a screaming deal for low compression rotors. What do you think? Do rotors have milled surfaces that could not be withing spec? or be milled to far? what should I check before buying these? thanks
Old Sep 19, 2002 | 09:31 PM
autocrash's Avatar
Now with more 1st Gen!
uhmm... look for a warranty? (seems like good advice to me) (maybe a return policy too? )
Old Sep 19, 2002 | 09:58 PM
blue87's Avatar
You will need the counter weight also, then have the whle assembly balanced..
Old Sep 20, 2002 | 12:26 AM
BrainFood's Avatar
how much do counterwieghts usually go for? I was just wondering if there was any machining done on the rotor that might cause problems for example if I was to buy used heads for a piston engine but they have been milled to many times it would cause a problem same with rotors?
Old Sep 20, 2002 | 12:35 AM
Kai's Avatar
Kai
Rotorphile.
You're not supposed to mill rotors... maybe he did, and that's why he's selling them
Old Sep 20, 2002 | 12:49 AM
BrainFood's Avatar
good point
Old Sep 20, 2002 | 12:52 AM
HWO's Avatar
HWO
inteligent extratarestril
just what exactly do you think race clearancing the rotors involves?????
MILLING THEM
Old Sep 20, 2002 | 01:44 AM
BrainFood's Avatar
what part do they mill to race clearance? also they are probably milled to fit the bigger 3mm apex seals right? I am not sure what that entales but they must make room somewhere
cristoDathird
28
May 30, 2019 08:47 PM
MoTeC
Sep 10, 2015 07:58 PM
Marty RE
Aug 17, 2015 09:36 AM
