Fuel controler?
Old Sep 19, 2002 | 07:51 PM
NRA T2's Avatar
Fuel controler?
I'm looking to add a Walbro pump and 720 secondaries, do I also have to get a controler like a S-AFC, or can I survive w/out it, I've already gone to search for answers but no luck
Old Sep 19, 2002 | 08:11 PM
rx74prez's Avatar
You probably wanna get a S-AFC will that setup you are going to run hella rich. You are also going to need a EGT gauge and an Air/Fuel gauge to turn your car or if there is a dyno with a wideband, even better.
Chris
Old Sep 19, 2002 | 08:52 PM
NRA T2's Avatar
I have an A/F gauge, the secondaries only come on @ higher rpms so if I raised my boost to compensate for the extra fuel would that work or do I still need the s-afc, also do I even need the 720's to raise my boost if i have the s-afc and the walbro??
Old Sep 19, 2002 | 10:38 PM
Ryde _Or_Die's Avatar
First off an a/f ratio gauge just works off the stock O2 sensor and is pretty much a light show. EGT gauges are much more accurate but even better is a wideband o2 sensor.
Now to be safe fuel wise, I'd go with a walbro pump, fcd, s-afc and 720cc secondaries. That way you don't have to worry and have control over your fuel. Its really not worth going the cheap route or risking anything.
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
