Fu*%ing vaccuum leak is griving me insane!!!
Old Sep 18, 2002 | 07:52 PM
boostmotorsport's Avatar
I have had this happen in the past and always find it, and fix it no problem. Worst case is I turn the boost up to 12psi and blow the hole open to find it easier. This one wont get worse, and I cant find it to make it better. My idle sucks(rough), the car drives all jerky at low Throttle pos.'s, the turbo whines like a bitch on spool up, and boost comes on slow as ****(all symptons of a vac leak). Also I can hear the leak, from driver side) at full boost wooshing away my HP, and sanity! I have removed the upper man. and searched 3 times now.
Any advice on finding it?
Old Oct 18, 2002 | 06:33 PM
reboot's Avatar
i spent more on tires...
Old Oct 18, 2002 | 08:28 PM
niner's Avatar
have you tried using propane or carb cleaner? try spraying it around all manifolds and everything to find it, there is a change in idle when you find the leak, it usually smooths out for a second.
have you looked at the injectors? the seals and pintle caps on them cause vac leak if they are bad
what was wrong w/ you car the last time it wouldnt run?
mike
Old Oct 19, 2002 | 12:10 AM
zenkiFC's Avatar
Danger to Manifold
have you tried that 2 inch rubber joint between the turbo and the bov? mine was cracked all to **** but i couldnt see it till i took it off. theres still another leak somewhere else though.
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
