my car's a heap
Old Sep 18, 2002 | 07:31 PM
RestoTII's Avatar
my car's a heap
ok, my car is running like ***. I thought it was either injectors, exhaust/intake leak, or a dead rotor. It's hard to start, and it's flooding (injectors). It's got no low end when I pull out and sounds like *** when I'm cruising around. It's not until around 3500 rpm that it starts picking up and even then I'm only seeing about 7-8 psi. It's gotten worse as I've been driving, and it didn't happen right after any of the mods, so I don't think i hurt anything when I put the intake and TID on. I ran injector cleaner through it and it's not feeling any better, so any suggestions? One guy said to check the manny to the turbo gasket, so that's a start, any others?
My mods are
RB turbo back exhaust
DIY Intake and TID
FCD
Removed Air Pump
Removed A/C
Old Sep 18, 2002 | 07:33 PM
bcty's Avatar
Boost This!
check for vacume leaks.. maybe run a little ATF though if it feeling really sluggish.. maybe some new plugs u need? try that..
Old Sep 18, 2002 | 07:48 PM
RestoTII's Avatar
if sounds like it might have a vac leak, but i can't see any. I don't have time to run ATF through it since I'm at school. I can't exactly put it in and let it sit instead of going to classes (though I've thought about it ). What about MMO? I used to use it and it felt fine, but i haven't added it in a while. BTW my vac's at 10 in-Hg at idle
Old Sep 18, 2002 | 09:12 PM
RestoTII's Avatar
??? any other suggestions? I didn't want to see another of my posts work it's way off the page before I came up with some kind of half-assed solution at least
Old Sep 19, 2002 | 08:36 AM
RestoTII's Avatar
I'll bump it once more in hopes that some gurus might be around this afternoon. By the way, the DIY BOV might be a little bit of a vac leak, but I don't think it's enough to cause these problems. I preloaded it a little more so it shouldn't leak much at all, and I got some MMO to put in the gas next time I'm out for a ride.
Old Sep 19, 2002 | 08:57 AM
VetteKiller's Avatar
check your TPS maybe?
Old Sep 19, 2002 | 09:56 AM
RestoTII's Avatar
hmm... that's one thing I haven't thought of yet. I've seen alot of people having probs with them, but would it cause such a lack of low end and low boost? Might be something i need to look into
cristoDathird
28
May 30, 2019 08:47 PM
astrum
24
Nov 15, 2017 08:44 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
